Action not containing all info?
  • SnIpY
    • Jan 2017
    I've configuered an action with the following default message:
    Severity: {TRIGGER.SEVERITY}
    Hostname: {HOSTNAME}
    Trigger: DEV-{TRIGGER.NAME}
    Status: {TRIGGER.STATUS}
    Date: {EVENT.DATE} {EVENT.TIME}
    Last value: {ITEM.LASTVALUE}
    Comment: {TRIGGER.COMMENT}
    However, when the action is send out, I only receive this:
    Severity: Warning
    Hostname: prod
    Trigger: DEV-Item stuck in the Queue
    Status: PROBLEM
    Date: 2017.04.07 08:56:10
    Last value: 230
    Com
    Anyone has a clue what might be going on here? Using Zabbix 3.2.4 (2017-03-15) XXL. © 2001–2017
  • batchenr
    • Sep 2016
    • 440
    Severity: Warning
    Hostname: prod
    Status: PROBLEM
    Last value: 230
    Com
    if you replace this Comment: {TRIGGER.COMMENT}
    with other macro just for tests, does it stile cut it ?
    • SnIpY
      • Jan 2017
      Yep,
      Ive tried with placing the severity as last, then that one is indeed cut
      • batchenr
        • Sep 2016
        • 440
        Yep,
        so i guss its a limitation issue ?
        maybe try to add another thing under that and see if it helps - if not
        maybe open zabbix a bug i have no clue.
        im using zabbix 3 and i dont have cuts there.
