Hello guys, the RabbitMQ announced that it deprecated the metrics delivery via the management API / UI https://www.rabbitmq.com/blog/2021/0...-announcements and the Zabbix template makes use of ui to obtain metrics. The RabbitMQ recommends using Prometheus. https://www.rabbitmq.com/docs/prometheus
Will we be able to monitor RabbitMQ with Zabbix?
I did a test with the indicated parameter with the logs of rabbitmq itself
We have some workaround, i'm thinking about creating a template to monitor rabbitmq, but using Prometheus
HTML Code:
2025-01-22 07:33:53 [warning] <0.xxxxx.0> To test RabbitMQ as if the feature was removed, set this in your configuration: 2025-01-22 07:33:53 [warning] <0.xxxxx.0> "deprecated_features.permit.management_metrics_col lection = false"
