custom trigger on large number of hosts
  • chrisbirley
    • Mar 2025
    Hi all
    ive done some searching, but it seems the google-fu is weak with me atm. im deploying Zabbix 7.2 atm. ive got it installed, deployed the agent to around 150 Windows based hosts, added some metadata into the install file to put machines into specific host groups. ive now come to wanting to get disk alerts. ive see the triggers in with what seems to be a pre-configured alert for low and very low disk space.
    ive changed the template macro, to do disk space as a value as opposed to percentage, im hoping to get a warnign at 15GB free, and critical at 5GB free. ive come to create the triggers to then get alerts, but i dont seem to be able to do a trigger alert within the template. it looks like i can this on a per host basis as the triggers for the host are more granular than then generic ones on the template. is it possible to update this on mass as opposed to having to do this for each individual host. or is there a better way of doing this
    thanks
