Problem with mysql_pconnect
  • guyp
    • Mar 2005
    • 9
    Hi.
    I've just installed zabbix, with all prerequisites, and when I try to open the web page, my browser return the following message:
    Fatal error: Call to undefined function: mysql_pconnect() in /var/www/html/include/db.inc.php on line 33
    Do I miss something ??
    please help !!
  • guyp
    • Mar 2005
    • 9
    I've tried several time to make it work and I was unable to.
    Maybe ZABBIX simply won't work on RedHat 9 ?
    I'm using :
    MySQL 4
    PHP 4
    php-mysql 4
    net-snmp 5
    Apache 2
    • eWebtricity
      • Mar 2005
      • 27
      Did you set the username and password for the MySQL DB. Sounds like it's just not able to access the MySQL DB you created, you did create it right? I just installed on Fedora Core 3 with few problems. I was up and running in a matter of hours once I read over the docs.
      I"m using
      MySQL 3.23.58
      PHP 4.3.10
      Apache 2.0
      Kernel 2.6.10
      • Ofntech
        • Mar 2005
        I had this same problem, make sure you have php-mysql installed and that you have setup mysql users.
        • rajeevtomar
          • Mar 2005
          • 50
          Problem can be resolved by installing mysql-dev package.as it contains header files and libraries.
          Cheers, Rajeev
