{TRIGGER.VALUE} is neither 1 nor 0
  • Ruddimaster
    • Dec 2016
    • 49
    Zabbix 7.2.4., MySQL DB, Ubuntu 24.04 LTS
    I can't say when I started having this problem. I guess after the upgrade to 7.2.
    To avoid toggling, I often work with {TRIGGER.VALUE}.
    Now I have the problem that
    ({TRIGGER.VALUE}=0 and last(/Server01/vfs.fs.size[D:,pfree])<10) or ({TRIGGER.VALUE}=1 and last(/Server01/vfs.fs.size[D:,pfree])<11)
    no longer works.
    The trigger is no longer activated under 10.
    works
    This senseless trigger goes to PROBLEM, but should not:
    ({TRIGGER.VALUE}<>0 and {TRIGGER.VALUE}<>1 and last(/Server01/vfs.fs.size[D:,pfree])<10)
    So apparently TRIGGER.VALUE is neither 1 nor 0.
    Does anyone also have the same problem?
  • Answer selected by Ruddimaster at 11-06-2025, 15:07.
    cyber
    • 4996
    Recovery expressions. Keeping it open until it is low enough to not flap..
    • Ruddimaster
      • Dec 2016
      • 49
      so I have done an other test:
      ({TRIGGER.VALUE}=0 or {TRIGGER.VALUE}=1) and last(/Server01/vfs.fs.size[D:,pfree])< 10
      If the trigger.value is 1 or 0 the or-link must be always true. but it isn't . I have still 9% free space. an the trigger is still OK.
      • Ruddimaster
        • Dec 2016
        • 49
        Has someone the same issue?
        • Ruddimaster
          • Dec 2016
          • 49
          I also have this behavior with a fresh installed appliance
          -> https://support.zabbix.com/browse/ZBX-26205
          • Ruddimaster
            • Dec 2016
            • 49
            Does any know what PS-2379 means?
            I can't see the actual status... I fearing that the Zabbix Development Team does not know that this important macro does not work?
              • 4996
              Without context, it can be anything..
              • Ruddimaster
                • Dec 2016
                • 49
                You will find the context at this URL https://support.zabbix.com/browse/ZBX-26205
                • Ruddimaster
                  • Dec 2016
                  • 49
                  Am I the only one who works with {TRIGGER.VALUE}, as this no longer works since 7.2?
                  • Ruddimaster
                    • Dec 2016
                    • 49
                    No one use {TRIGGER.VALUE}?
                      • 4996
                      TBH, not using it... But bug seems to be confirmed, pity, it is not worked on..
                      • Ruddimaster
                        • Dec 2016
                        • 49
                        Thanks for you're response.
                        How do you prevent this from happening when a value goes back and forth just at the limit of the threshold value?
                        In my environment the trigger memory and disk usage often toggle. To prevent this I use e.g.
                        In Nagios/Icinga there was a built-in default setting called flap detection:
                        "https://assets.nagios.com/downloads/nagioscore/docs/nagioscore/3/en/flapping.htm
                        At this blog there was an idea to rebuild this (from founder itself):
                        https://blog.zabbix.com/no-more-flap...mart-way/1488/
                        And now the developers are letting this issue lie for months
                          • 4996
                          • Ruddimaster
                            • Dec 2016
                            • 49
                            Thanks for this hint... it was hard work to change all my templates, but It works..
