ping checks on host with multiple IPs
  • Mechanix
    • Jan 2017
    • 92
    we have a couple of router which have more then 10 IP interfaces each. I would like to monitor this interfaces with icmp.
    As I understood, the IPs are added as Agent interfaces but how can I create a item/trigger for those interfaces from a template?
    Right now, I did this by hand but it´s a cumbersome work creating for every IP a item + trigger. Is there another way to achieve this?
    Thank you
  • ovas
    • Apr 2017
    • 138
    Hello!
    Low-level discovery may be your answer, more information available in documentation with step-by-step instructions: https://www.zabbix.com/documentation...ork_interfaces
    • Mechanix
      • Jan 2017
      • 92
      yeah, this would have worked if I could install the agent on the network devices
      • ovas
        • Apr 2017
        • 138
        Hello!
        Yes, sorry, I missed that little detail about network devices. Agent-less checks are also available for discovery, in your case, SNMP discovery. The example is available on the same page.
