Windows 2016 Agent 2 Issue - Not Being Discovered by Zabbix
  • Mayhem
    • Feb 2025
    • 9
    We've been migrating off of SCOM to Zabbix for a while now, and it's mostly been good, but we have one server that does not want to cooperate. We've installed the Zabbix Agent 2 and verified that the ports are open on the network firewall, bit the Zabbix server is not discovering it. We've confirmed the service has started, tried restarting, and tried reinstalling the agent, but no change. I also fail to see anything in the logs that would explain what is happening, but I'm including them here just in case.
    Its a Windows 2016 server.
    2025/03/25 02:55:46.605893 Starting Zabbix Agent 2 (7.0.5)
    2025/03/25 02:55:46.608894 OpenSSL library (OpenSSL 3.0.11 19 Sep 2023) initialized
    2025/03/25 02:55:46.609407 using configuration file: C:\Program Files\Zabbix Agent 2\zabbix_agent2.conf
    2025/03/25 02:55:46.609407 using plugin 'Agent' (built-in) providing following interfaces: exporter
    2025/03/25 02:55:46.609407 using plugin 'Ceph' (built-in) providing following interfaces: exporter, runner, configurator
    2025/03/25 02:55:46.609407 using plugin 'Cpu' (built-in) providing following interfaces: exporter, collector, runner
    2025/03/25 02:55:46.609407 using plugin 'DNS' (built-in) providing following interfaces: exporter
    2025/03/25 02:55:46.611044 using plugin 'File' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 02:55:46.611044 using plugin 'Log' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 02:55:46.611044 using plugin 'MQTT' (built-in) providing following interfaces: watcher, configurator
    2025/03/25 02:55:46.611044 using plugin 'Memcached' (built-in) providing following interfaces: exporter, runner, configurator
    2025/03/25 02:55:46.611553 using plugin 'Memory' (built-in) providing following interfaces: exporter
    2025/03/25 02:55:46.611553 using plugin 'Modbus' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 02:55:46.611553 using plugin 'Mysql' (built-in) providing following interfaces: exporter, runner, configurator
    2025/03/25 02:55:46.611553 using plugin 'NetIf' (built-in) providing following interfaces: exporter
    2025/03/25 02:55:46.611553 using plugin 'Oracle' (built-in) providing following interfaces: exporter, runner, configurator
    2025/03/25 02:55:46.611553 using plugin 'Proc' (built-in) providing following interfaces: exporter
    2025/03/25 02:55:46.611553 using plugin 'Redis' (built-in) providing following interfaces: exporter, runner, configurator
    2025/03/25 02:55:46.611553 using plugin 'Registry' (built-in) providing following interfaces: exporter
    2025/03/25 02:55:46.611553 using plugin 'Smart' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 02:55:46.611553 using plugin 'Sw' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 02:55:46.611553 using plugin 'Swap' (built-in) providing following interfaces: exporter
    2025/03/25 02:55:46.611553 using plugin 'SystemRun' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 02:55:46.611553 using plugin 'TCP' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 02:55:46.611553 using plugin 'UDP' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 02:55:46.611553 using plugin 'Uname' (built-in) providing following interfaces: exporter
    2025/03/25 02:55:46.611553 using plugin 'Uptime' (built-in) providing following interfaces: exporter
    2025/03/25 02:55:46.611553 using plugin 'Users' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 02:55:46.611553 using plugin 'VFSDir' (built-in) providing following interfaces: exporter
    2025/03/25 02:55:46.611553 using plugin 'VMemory' (built-in) providing following interfaces: exporter
    2025/03/25 02:55:46.611553 using plugin 'VfsFs' (built-in) providing following interfaces: exporter
    2025/03/25 02:55:46.611553 using plugin 'WebCertificate' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 02:55:46.611553 using plugin 'WebPage' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 02:55:46.611553 using plugin 'WindowsEventlog' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 02:55:46.611553 lowering the plugin WindowsPerfInstance capacity to 1 as the configured capacity 1000 exceeds limits
    2025/03/25 02:55:46.611553 using plugin 'WindowsPerfInstance' (built-in) providing following interfaces: exporter
    2025/03/25 02:55:46.611553 using plugin 'WindowsPerfMon' (built-in) providing following interfaces: exporter, collector, runner
    2025/03/25 02:55:46.611553 using plugin 'WindowsServices' (built-in) providing following interfaces: exporter
    2025/03/25 02:55:46.611553 using plugin 'Wmi' (built-in) providing following interfaces: exporter
    2025/03/25 02:55:46.611553 using plugin 'ZabbixAsync' (built-in) providing following interfaces: exporter
    2025/03/25 02:55:46.611553 using plugin 'ZabbixStats' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 02:55:46.611553 lowering the plugin ZabbixSync capacity to 1 as the configured capacity 1000 exceeds limits
    2025/03/25 02:55:46.611553 using plugin 'ZabbixSync' (built-in) providing following interfaces: exporter
    2025/03/25 02:55:47.653887 Plugin communication protocol version is 6.4.0
    2025/03/25 02:55:48.001422 Zabbix Agent2 hostname: [randomhost]
    2025/03/25 03:10:49.195675 Zabbix Agent 2 stopped. (7.0.5)
    2025/03/25 03:10:50.576404 Starting Zabbix Agent 2 (7.0.5)
    2025/03/25 03:10:50.579539 OpenSSL library (OpenSSL 3.0.11 19 Sep 2023) initialized
    2025/03/25 03:10:50.579539 using configuration file: C:\Program Files\Zabbix Agent 2\zabbix_agent2.conf
    2025/03/25 03:10:50.579539 using plugin 'Agent' (built-in) providing following interfaces: exporter
    2025/03/25 03:10:50.580078 using plugin 'Ceph' (built-in) providing following interfaces: exporter, runner, configurator
    2025/03/25 03:10:50.580078 using plugin 'Cpu' (built-in) providing following interfaces: exporter, collector, runner
    2025/03/25 03:10:50.580078 using plugin 'DNS' (built-in) providing following interfaces: exporter
    2025/03/25 03:10:50.580078 using plugin 'File' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:10:50.580078 using plugin 'Log' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:10:50.580078 using plugin 'MQTT' (built-in) providing following interfaces: watcher, configurator
    2025/03/25 03:10:50.580613 using plugin 'Memcached' (built-in) providing following interfaces: exporter, runner, configurator
    2025/03/25 03:10:50.580613 using plugin 'Memory' (built-in) providing following interfaces: exporter
    2025/03/25 03:10:50.580613 using plugin 'Modbus' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:10:50.580613 using plugin 'Mysql' (built-in) providing following interfaces: exporter, runner, configurator
    2025/03/25 03:10:50.580613 using plugin 'NetIf' (built-in) providing following interfaces: exporter
    2025/03/25 03:10:50.580613 using plugin 'Oracle' (built-in) providing following interfaces: exporter, runner, configurator
    2025/03/25 03:10:50.580613 using plugin 'Proc' (built-in) providing following interfaces: exporter
    2025/03/25 03:10:50.581152 using plugin 'Redis' (built-in) providing following interfaces: exporter, runner, configurator
    2025/03/25 03:10:50.581152 using plugin 'Registry' (built-in) providing following interfaces: exporter
    2025/03/25 03:10:50.581152 using plugin 'Smart' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:10:50.581152 using plugin 'Sw' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:10:50.581152 using plugin 'Swap' (built-in) providing following interfaces: exporter
    2025/03/25 03:10:50.581152 using plugin 'SystemRun' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:10:50.581688 using plugin 'TCP' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:10:50.581688 using plugin 'UDP' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:10:50.581688 using plugin 'Uname' (built-in) providing following interfaces: exporter
    2025/03/25 03:10:50.581688 using plugin 'Uptime' (built-in) providing following interfaces: exporter
    2025/03/25 03:10:50.581688 using plugin 'Users' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:10:50.582222 using plugin 'VFSDir' (built-in) providing following interfaces: exporter
    2025/03/25 03:10:50.582222 using plugin 'VMemory' (built-in) providing following interfaces: exporter
    2025/03/25 03:10:50.582222 using plugin 'VfsFs' (built-in) providing following interfaces: exporter
    2025/03/25 03:10:50.582222 using plugin 'WebCertificate' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:10:50.582222 using plugin 'WebPage' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:10:50.582757 using plugin 'WindowsEventlog' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:10:50.582757 lowering the plugin WindowsPerfInstance capacity to 1 as the configured capacity 1000 exceeds limits
    2025/03/25 03:10:50.582757 using plugin 'WindowsPerfInstance' (built-in) providing following interfaces: exporter
    2025/03/25 03:10:50.582757 using plugin 'WindowsPerfMon' (built-in) providing following interfaces: exporter, collector, runner
    2025/03/25 03:10:50.582757 using plugin 'WindowsServices' (built-in) providing following interfaces: exporter
    2025/03/25 03:10:50.582757 using plugin 'Wmi' (built-in) providing following interfaces: exporter
    2025/03/25 03:10:50.582757 using plugin 'ZabbixAsync' (built-in) providing following interfaces: exporter
    2025/03/25 03:10:50.583290 using plugin 'ZabbixStats' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:10:50.583290 lowering the plugin ZabbixSync capacity to 1 as the configured capacity 1000 exceeds limits
    2025/03/25 03:10:50.583290 using plugin 'ZabbixSync' (built-in) providing following interfaces: exporter
    2025/03/25 03:10:51.458607 Plugin communication protocol version is 6.4.0
    2025/03/25 03:10:52.006700 Zabbix Agent2 hostname: [randomhost]
    2025/03/25 03:18:28.514689 Zabbix Agent 2 stopped. (7.0.5)
    2025/03/25 03:19:30.574444 Starting Zabbix Agent 2 (7.0.5)
    2025/03/25 03:19:30.578224 OpenSSL library (OpenSSL 3.0.11 19 Sep 2023) initialized
    2025/03/25 03:19:30.578224 using configuration file: C:\Program Files\Zabbix Agent 2\zabbix_agent2.conf
    2025/03/25 03:19:30.578224 using plugin 'Agent' (built-in) providing following interfaces: exporter
    2025/03/25 03:19:30.578769 using plugin 'Ceph' (built-in) providing following interfaces: exporter, runner, configurator
    2025/03/25 03:19:30.578769 using plugin 'Cpu' (built-in) providing following interfaces: exporter, collector, runner
    2025/03/25 03:19:30.578769 using plugin 'DNS' (built-in) providing following interfaces: exporter
    2025/03/25 03:19:30.578769 using plugin 'File' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:19:30.578769 using plugin 'Log' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:19:30.578769 using plugin 'MQTT' (built-in) providing following interfaces: watcher, configurator
    2025/03/25 03:19:30.579302 using plugin 'Memcached' (built-in) providing following interfaces: exporter, runner, configurator
    2025/03/25 03:19:30.579302 using plugin 'Memory' (built-in) providing following interfaces: exporter
    2025/03/25 03:19:30.579302 using plugin 'Modbus' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:19:30.579302 using plugin 'Mysql' (built-in) providing following interfaces: exporter, runner, configurator
    2025/03/25 03:19:30.579302 using plugin 'NetIf' (built-in) providing following interfaces: exporter
    2025/03/25 03:19:30.579302 using plugin 'Oracle' (built-in) providing following interfaces: exporter, runner, configurator
    2025/03/25 03:19:30.579302 using plugin 'Proc' (built-in) providing following interfaces: exporter
    2025/03/25 03:19:30.579834 using plugin 'Redis' (built-in) providing following interfaces: exporter, runner, configurator
    2025/03/25 03:19:30.579834 using plugin 'Registry' (built-in) providing following interfaces: exporter
    2025/03/25 03:19:30.579834 using plugin 'Smart' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:19:30.579834 using plugin 'Sw' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:19:30.579834 using plugin 'Swap' (built-in) providing following interfaces: exporter
    2025/03/25 03:19:30.579834 using plugin 'SystemRun' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:19:30.579834 using plugin 'TCP' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:19:30.580371 using plugin 'UDP' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:19:30.580371 using plugin 'Uname' (built-in) providing following interfaces: exporter
    2025/03/25 03:19:30.580371 using plugin 'Uptime' (built-in) providing following interfaces: exporter
    2025/03/25 03:19:30.580371 using plugin 'Users' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:19:30.580371 using plugin 'VFSDir' (built-in) providing following interfaces: exporter
    2025/03/25 03:19:30.580371 using plugin 'VMemory' (built-in) providing following interfaces: exporter
    2025/03/25 03:19:30.580902 using plugin 'VfsFs' (built-in) providing following interfaces: exporter
    2025/03/25 03:19:30.580902 using plugin 'WebCertificate' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:19:30.580902 using plugin 'WebPage' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:19:30.580902 using plugin 'WindowsEventlog' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:19:30.580902 lowering the plugin WindowsPerfInstance capacity to 1 as the configured capacity 1000 exceeds limits
    2025/03/25 03:19:30.580902 using plugin 'WindowsPerfInstance' (built-in) providing following interfaces: exporter
    2025/03/25 03:19:30.580902 using plugin 'WindowsPerfMon' (built-in) providing following interfaces: exporter, collector, runner
    2025/03/25 03:19:30.581432 using plugin 'WindowsServices' (built-in) providing following interfaces: exporter
    2025/03/25 03:19:30.581432 using plugin 'Wmi' (built-in) providing following interfaces: exporter
    2025/03/25 03:19:30.581432 using plugin 'ZabbixAsync' (built-in) providing following interfaces: exporter
    2025/03/25 03:19:30.581432 using plugin 'ZabbixStats' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:19:30.581432 lowering the plugin ZabbixSync capacity to 1 as the configured capacity 1000 exceeds limits
    2025/03/25 03:19:30.581432 using plugin 'ZabbixSync' (built-in) providing following interfaces: exporter
    2025/03/25 03:19:31.487061 Plugin communication protocol version is 6.4.0
    2025/03/25 03:19:32.006026 Zabbix Agent2 hostname: [randomhost]
    2025/03/25 03:19:51.028007 Zabbix Agent 2 stopped. (7.0.5)
    2025/03/25 03:20:07.965283 Starting Zabbix Agent 2 (7.0.5)
    2025/03/25 03:20:07.968782 OpenSSL library (OpenSSL 3.0.11 19 Sep 2023) initialized
    2025/03/25 03:20:07.968782 using configuration file: C:\Program Files\Zabbix Agent 2\zabbix_agent2.conf
    2025/03/25 03:20:07.969312 using plugin 'Agent' (built-in) providing following interfaces: exporter
    2025/03/25 03:20:07.969312 using plugin 'Ceph' (built-in) providing following interfaces: exporter, runner, configurator
    2025/03/25 03:20:07.969312 using plugin 'Cpu' (built-in) providing following interfaces: exporter, collector, runner
    2025/03/25 03:20:07.969312 using plugin 'DNS' (built-in) providing following interfaces: exporter
    2025/03/25 03:20:07.969312 using plugin 'File' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:20:07.969312 using plugin 'Log' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:20:07.969828 using plugin 'MQTT' (built-in) providing following interfaces: watcher, configurator
    2025/03/25 03:20:07.969828 using plugin 'Memcached' (built-in) providing following interfaces: exporter, runner, configurator
    2025/03/25 03:20:07.969828 using plugin 'Memory' (built-in) providing following interfaces: exporter
    2025/03/25 03:20:07.969828 using plugin 'Modbus' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:20:07.969828 using plugin 'Mysql' (built-in) providing following interfaces: exporter, runner, configurator
    2025/03/25 03:20:07.969828 using plugin 'NetIf' (built-in) providing following interfaces: exporter
    2025/03/25 03:20:07.969828 using plugin 'Oracle' (built-in) providing following interfaces: exporter, runner, configurator
    2025/03/25 03:20:07.969828 using plugin 'Proc' (built-in) providing following interfaces: exporter
    2025/03/25 03:20:07.969828 using plugin 'Redis' (built-in) providing following interfaces: exporter, runner, configurator
    2025/03/25 03:20:07.969828 using plugin 'Registry' (built-in) providing following interfaces: exporter
    2025/03/25 03:20:07.969828 using plugin 'Smart' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:20:07.969828 using plugin 'Sw' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:20:07.969828 using plugin 'Swap' (built-in) providing following interfaces: exporter
    2025/03/25 03:20:07.969828 using plugin 'SystemRun' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:20:07.969828 using plugin 'TCP' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:20:07.971790 using plugin 'UDP' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:20:07.971790 using plugin 'Uname' (built-in) providing following interfaces: exporter
    2025/03/25 03:20:07.971790 using plugin 'Uptime' (built-in) providing following interfaces: exporter
    2025/03/25 03:20:07.971790 using plugin 'Users' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:20:07.971790 using plugin 'VFSDir' (built-in) providing following interfaces: exporter
    2025/03/25 03:20:07.972331 using plugin 'VMemory' (built-in) providing following interfaces: exporter
    2025/03/25 03:20:07.972331 using plugin 'VfsFs' (built-in) providing following interfaces: exporter
    2025/03/25 03:20:07.972331 using plugin 'WebCertificate' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:20:07.972331 using plugin 'WebPage' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:20:07.972331 using plugin 'WindowsEventlog' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:20:07.972331 lowering the plugin WindowsPerfInstance capacity to 1 as the configured capacity 1000 exceeds limits
    2025/03/25 03:20:07.972331 using plugin 'WindowsPerfInstance' (built-in) providing following interfaces: exporter
    2025/03/25 03:20:07.972865 using plugin 'WindowsPerfMon' (built-in) providing following interfaces: exporter, collector, runner
    2025/03/25 03:20:07.972865 using plugin 'WindowsServices' (built-in) providing following interfaces: exporter
    2025/03/25 03:20:07.972865 using plugin 'Wmi' (built-in) providing following interfaces: exporter
    2025/03/25 03:20:07.972865 using plugin 'ZabbixAsync' (built-in) providing following interfaces: exporter
    2025/03/25 03:20:07.972865 using plugin 'ZabbixStats' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:20:07.972865 lowering the plugin ZabbixSync capacity to 1 as the configured capacity 1000 exceeds limits
    2025/03/25 03:20:07.972865 using plugin 'ZabbixSync' (built-in) providing following interfaces: exporter
    2025/03/25 03:20:08.742267 Plugin communication protocol version is 6.4.0
    2025/03/25 03:20:09.002325 Zabbix Agent2 hostname: [randomhost]
    2025/03/25 03:20:55.139166 Zabbix Agent 2 stopped. (7.0.5)
    2025/03/25 03:20:56.523020 Starting Zabbix Agent 2 (7.0.5)
    2025/03/25 03:20:56.526596 OpenSSL library (OpenSSL 3.0.11 19 Sep 2023) initialized
    2025/03/25 03:20:56.526700 using configuration file: C:\Program Files\Zabbix Agent 2\zabbix_agent2.conf
    2025/03/25 03:20:56.526700 using plugin 'Agent' (built-in) providing following interfaces: exporter
    2025/03/25 03:20:56.526700 using plugin 'Ceph' (built-in) providing following interfaces: exporter, runner, configurator
    2025/03/25 03:20:56.526700 using plugin 'Cpu' (built-in) providing following interfaces: exporter, collector, runner
    2025/03/25 03:20:56.527230 using plugin 'DNS' (built-in) providing following interfaces: exporter
    2025/03/25 03:20:56.527230 using plugin 'File' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:20:56.527230 using plugin 'Log' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:20:56.527230 using plugin 'MQTT' (built-in) providing following interfaces: watcher, configurator
    2025/03/25 03:20:56.527230 using plugin 'Memcached' (built-in) providing following interfaces: exporter, runner, configurator
    2025/03/25 03:20:56.527230 using plugin 'Memory' (built-in) providing following interfaces: exporter
    2025/03/25 03:20:56.527760 using plugin 'Modbus' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:20:56.527760 using plugin 'Mysql' (built-in) providing following interfaces: exporter, runner, configurator
    2025/03/25 03:20:56.527760 using plugin 'NetIf' (built-in) providing following interfaces: exporter
    2025/03/25 03:20:56.527760 using plugin 'Oracle' (built-in) providing following interfaces: exporter, runner, configurator
    2025/03/25 03:20:56.527760 using plugin 'Proc' (built-in) providing following interfaces: exporter
    2025/03/25 03:20:56.527760 using plugin 'Redis' (built-in) providing following interfaces: exporter, runner, configurator
    2025/03/25 03:20:56.528287 using plugin 'Registry' (built-in) providing following interfaces: exporter
    2025/03/25 03:20:56.528287 using plugin 'Smart' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:20:56.528287 using plugin 'Sw' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:20:56.528287 using plugin 'Swap' (built-in) providing following interfaces: exporter
    2025/03/25 03:20:56.528287 using plugin 'SystemRun' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:20:56.528287 using plugin 'TCP' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:20:56.528287 using plugin 'UDP' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:20:56.528817 using plugin 'Uname' (built-in) providing following interfaces: exporter
    2025/03/25 03:20:56.528817 using plugin 'Uptime' (built-in) providing following interfaces: exporter
    2025/03/25 03:20:56.528817 using plugin 'Users' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:20:56.528817 using plugin 'VFSDir' (built-in) providing following interfaces: exporter
    2025/03/25 03:20:56.528817 using plugin 'VMemory' (built-in) providing following interfaces: exporter
    2025/03/25 03:20:56.528817 using plugin 'VfsFs' (built-in) providing following interfaces: exporter
    2025/03/25 03:20:56.528817 using plugin 'WebCertificate' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:20:56.529344 using plugin 'WebPage' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:20:56.529344 using plugin 'WindowsEventlog' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:20:56.529344 lowering the plugin WindowsPerfInstance capacity to 1 as the configured capacity 1000 exceeds limits
    2025/03/25 03:20:56.529344 using plugin 'WindowsPerfInstance' (built-in) providing following interfaces: exporter
    2025/03/25 03:20:56.529344 using plugin 'WindowsPerfMon' (built-in) providing following interfaces: exporter, collector, runner
    2025/03/25 03:20:56.529344 using plugin 'WindowsServices' (built-in) providing following interfaces: exporter
    2025/03/25 03:20:56.529854 using plugin 'Wmi' (built-in) providing following interfaces: exporter
    2025/03/25 03:20:56.529874 using plugin 'ZabbixAsync' (built-in) providing following interfaces: exporter
    2025/03/25 03:20:56.529874 using plugin 'ZabbixStats' (built-in) providing following interfaces: exporter, configurator
    2025/03/25 03:20:56.529874 lowering the plugin ZabbixSync capacity to 1 as the configured capacity 1000 exceeds limits
    2025/03/25 03:20:56.529874 using plugin 'ZabbixSync' (built-in) providing following interfaces: exporter
    2025/03/25 03:20:57.295161 Plugin communication protocol version is 6.4.0
    2025/03/25 03:20:58.015327 Zabbix Agent2 hostname: [randomhost]
