Apache template triggers issue
  • f4242
    • Oct 2024
    Is there something I don't understand or I do wrong or the Apache by Zabbix agent template is not working as expected? I'm using the version 7.0-1 found on git repository.
    It detects apache process with a discovery rule. Not sure why it's done that way, why I would have many apache server running? Anyway, this is not the point.
    The discovery rule include triggers prototypes. One of theses triggers is to alert if there is apache process running...
    But if the apache service is stopped, the LLD disable all discovered elements because they are now missing. So no triggers are triggered. No alert if the service is down!
    So, should I move the elements/triggers found in the LLD and hard code them in the template or do I miss something?
    Thanks!
    • 5004
    I think you are right... that is not the smartest way to discover those... If processes are gone,.everything about them is also gone.. Hardcoding it all would solve your issue
    • mrnobody
      • Oct 2024
      • 61
      Try create a item without LLD, it's usage is like ps aux | grep process
      SNMP Walk/Get 1.3.6.1.2.1.25.4.2.1.2 or create a SNMP Agent item directly with this OID and Regex in preprocessing, or 1.3.6.1.2.1.25.4.2.1.2["index","1.3.6.1.2.1.25.4.2.1.2","PROCESSNAME"]
      If it returns, it's running.
        • 5004
        not everyone has snmp agent running ...
