Trigger didn't generate events
  • pipidoudou
    • Apr 2017
    Version:Zabbix Server Updated from 2.2.9 to 3.2.5
    zabbix agent trigger "Zabbix agent on HOST.NAME is unreachable for 3 minutes" could not generate events or problems.
    can't submit log……later
  • pipidoudou
    • Apr 2017
    Agent.ping.nodata(15m) could not generate events
    Zabbix server updated from 2.2.9 to 3.2.5
    Server log shows that function nodata had been 1.But trigger value didn't change.And no events were triggerd.
    1、Here's server log when agent was running:
    18197:20170425:110300.658 In zbx_substitute_functions_results() ifuncs_num:12 tr_num:9
    18197:20170425:110300.659 zbx_substitute_functions_results() expression[8]:'{13590}=1' => '0=1'
     18197:20170425:110300.659 End of zbx_substitute_functions_results()
     18197:20170425:110300.659 End of substitute_functions()
     [B]18197:20170425:110300.659 In evaluate() expression:'0=1'[/B]
     18197:20170425:110300.659 End of evaluate() value:0.000000
     18197:20170425:110300.659 End of evaluate_expressions()
     18197:20170425:110300.659 query [txnlev:1] [begin;]
     18197:20170425:110300.660 [B]In zbx_process_trigger() triggerid:13794 value:0(0) new_value:3[/B]
     18197:20170425:110300.660 End of zbx_process_trigger():FAIL flags:0
     18197:20170425:110300.660 End of zbx_process_triggers()
    2、Here's server log when agent was down and no data received more than 3min:
    [B] 18197:20170425:110400.685 zbx_substitute_functions_results() expression[8]:'{13590}=1' => '1=1'[/B]
     [B]18197:20170425:110400.686 In evaluate() expression:'1=1'[/B]
     18197:20170425:110400.686 End of evaluate_expressions()
     [B]18197:20170425:110400.687 In zbx_process_trigger() triggerid:13794 value:0(0) new_value:3[/B]
     18197:20170425:110400.687 End of zbx_process_trigger():FAIL flags:0
     18197:20170425:110400.687 End of zbx_process_triggers()
     [B]18197:20170425:110400.687 In process_trigger_events() events_num:0[/B]
    • vergil
      • Apr 2017
      Yeah, i encountered this yesterday when i upgraded my installation from 3.0 to 3.2.5.
      In 3.2.5 triggers with nodata function doesn't work. I checked all versions previous to 3.2.5 (3.2.0-3.2.4) and it's working.
      • Kachou
        • Feb 2020
        • 10
        I have the same problem but I work with a zabbix 4.4.
        Do you have a solution to this problem please?
        Thank you in advance.
        Kachou
