Oracle 10g and 1.1.4 login problem
  • Sandor Feher
    • Oct 2004
    I would like to run zabbix with my oracle 10g database.
    Here is what i did:
    Installed libsqlora8 then compiled --enable-server --enable-agent --with-oracle=/usr/local
    It has compiled successfully.
    I created the database schema and called it zabbix with passwd zabbix.
    I set server config file under /etc/zabbix/ then tried to start zabbix_server.
    # Database host name
    # Default is localhost
    DBHost=localhost
    # Database name
    DBName=oracle
    # Database user
    DBUser=zabbix
    # Database password
    # Comment this line if no password used
    DBPassword=zabbix
    I get the following error message:
    030247:20070104:220110 Starting zabbix_server. ZABBIX 1.1.4.
    030247:20070104:220110 Cannot login with zabbix/zabbix@oracle
    However I can login in with sqlplus used the user/pass above.
    thanks in advance,, Sandor
  • Sandor Feher
    • Oct 2004
    Some additional information.
    This is a RHEL 4 with 2.6.9-5.EL
    libsqlora8-2.3.3 installed and works fine if i run ./testlora zabbix/zabbix@oracle
    But I had to set ORACLE_HOME var to get libsqlora8 worked.
    I did the same at the beginning of the zabbix_server_ctl script but nothing changed.
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      Perhaps you could check Oracle side (logs) to see what is wrong.
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
      • Sandor Feher
        • Oct 2004
        Goddam. You can't believe this. I was thinking on the suckerd starting process and realized that it becomes zabbix user first then does the rest of the things eg db connect too. I su-ed to zabbix and saw that it unable to see my oracle home and i know it have to reach oracle's libraries. So I changed zabbix's group to oinstall and voila. Started.
