Problems with Dashboard Widget "Problems by Severity", Timeline wrongly sorted
  • riBoon
    • May 2017
    • 30
    we were experimenting with the Dashboard widget "Problems by severity"
    I've attached the configured options as screenshot.
    The widget looks good so far. But one thing is a real problem: the alarms should be sorted by time and the icon idicates this, but they were sorted randomly (or in a strange way) if there are many hosts to display. I attached the resulted timeline also.
    Someone had this problem before? I didn't find something about this problem with my searches.
    We were using a old version (5.0.45). Maybe it's fixed in a newer one? I will try this if I have time for this.
    Edit: Important: You have to set Show "Totals" and not Show "Host groups" - if Host groups is set all seems to be fine.
