I have a simple perl script that grabs some info about Zabbix hosts using perl JSON commands.
Works fine on zabbix 2.4.5 but when I try same script from client with same config it gives JSON error:
malformed JSON string, neither tag, array, object, number, string or atom, at character offset 0 (before "(end of string)") at (eval 4) line 161.
The data I'm gathering is:
my $json_item_get = JSON::XS->new->pretty(0)->encode(
{ jsonrpc => 2.0,
method => "item.get",
params => {
output => ['hostid','state','name','status','error'],
auth => "$auth",
id => 2
If I change the "output" line to "output => ['hostid','state','status','error']" or "output => ['hostid','state','name']," it works fine.
Not sure why adding the 5 columns causes it to break.
I'm running on centos 7:
perl-JSON-2.90-1.of.el7.noarch
perl-JSON-XS-3.01-2.el7.x86_64
{ jsonrpc => 2.0,
params => {
auth => "$auth",
id => 2
