Unable to add tags for some triggers
  • c.lelu
    • Feb 2025
    Hello
    I'm trying to add tags for the différent triggers.
    For the moment, I'm only using the admin login (so it's not a problem of permission), but it seems not be allowed.
    For example, the triggers created by the "docker by zabbix agent 2" or "Linux by Zabbix agent".
    Even the add-button in the tag-triggers management page is grey.
    I'm using zabbix 6.0
    Is there a solution for that ?
    Thank you for your help.
  • kyus
    • Feb 2024
    • 204
    Most likely, you are trying to add tags to triggers that were added by trigger prototypes from the discovery rules.
    While you can manually add tags to templated triggers (not the discovered ones), i wouldn't recommend doing so, because it can get annoying to manage.
    To add tags to those triggers that were created by a discovery rule, you'll have to do it directly in your template, e.g. "Docker by Zabbix agent 2".
    Go to template "Discovery rules" tab, then go to "Trigger (or item) prototypes" and add the desired tags to those.
    • c.lelu
      • Feb 2025
      Yes : the problem is that I can't add tags on discovered triggers.
      And this is the goal : indeed I want to link each trigger to a software instance, recorded in a CMDB...
      So, for me, creating the tag on the discovery rules is not really a solution.
      I have made an page based on the api for managing this....
        • 4996
        Yes it is disabled, if you go into that triggers config. But you can go to any hosts config, select triggers/items created by discovery from the list and do "mass update" and add what you need...
        • kyus
          kyus commented
          Is this something only available to newer releases? Because, at least in my environment, it resulted in an error.
        • 4996
        I swear it was working yesterday... Or.. maybe I was not pressing the update button... :/ but as nothing seemed to be disabled or greyed out, then I made an assumption... which we all know means... assume, makes an ass of U and ME....
