Value Mapping Missing
  • Rickw
    • Oct 2023
    • 9
    Hello, I am running Zabbix 6.0.39 and I went to go use / setup a new value mapping and I do not have the option. I am logged in as a Super User as well as I have also logged in as Administrator and the options are not available. Administration/GUI Drop down GUI and pick "Value Mappin" is not there or anywhere I look. I also check at the item level but when I go to the Value Mapping box it's blank. How do I get this back??
  • kyus
    • Feb 2024
    • 211
    You should configure value mapping in your template or host, then you apply it to your items.
    • Rickw
      • Oct 2023
      • 9
      Hello kyus I agree but under Administration/General I don't have the "Value Mapping" option. Also when I go into the item in a template, I have no way to add a Value Mapping, it's just blank. So I'm really puzzled
      • kyus
        • Feb 2024
        • 211
        Well, you're not supposed to see any Value mapping under Administration/General, so that's not an error.
        You don't see any value mapping in the items of the template because you need to create a value mapping in the template configuration form.
        Read the documentation about it:
        • Rickw
          • Oct 2023
          • 9
          I now see that, I thought these were global but I now found it in the template... Thank you!! Appreciate the help
            • 5004
            Value mappings were global, but were moved to templates... maybe somewhere in v5...
