zabbix 7.2.5 proxy groups
  • psargent
    • Apr 2025
    I have 2 proxy servers in a proxy group. The set up was working correctly. After a network blip, the proxy group alerted with a Status "offline". Since then I have not been able to get the group working again. Both of the proxy hosts work if they are the only host in the group, when both are in the group, one works and the other doesn't. They broken proxy logs "cannot send list of active checks to <IP>: host not found". I have tried stopping and starting the proxies. I have rebooted. I have stopped them both at the same time and started them both. I have tried changing the agent hostname to FQDN. Nothing has worked yet. This has happened once before, and after some amount of time and restarts, it starting working again. It is currently not working. How do I get it back up and working?
  • mrnobody
    • Oct 2024
    • 61
    Do you have H.A between servers? I would test it there too, if it's only your network, probably same would happen; just to have an base of comparition (knowing H.A between servers (old and mature feature) is different of H.A between proxys (new, baby born feature)). Think both H.A features depend of DNS resolution (if use hostnames in config files), specific firewall rules (may be the cause ) or just an problematic network (that i hope yours isen't another one).
    • psargent
      • Apr 2025
      Hello, Thank you for your replies. I appreciate it. It is finally working again. It is hard to say what exactly fixed it, but I think it was a combination of the following:
      1) I changed the trapper port to a custom port number and made sure all the configuration had the new port
      2) I deleted the hosts that were in the proxy (because as you will see below I changed the hostname)
      3) I created a new proxy group and moved the proxies to the new group
      4) I changed the hostname of the hosts on the proxy from hostname to FQDN
      So in summary, I deleted the hosts, created a new proxy group, added the hosts back in with FQDN and it is working now on a custom port.
      • psargent
        • Apr 2025
        Even after all of the above work, I continue to have issues with the proxy cluster. The proxies fail with error message "host not found". Deleting and recreating every proxy server is not a sustainable solution. Is there anything else I should try?
        • skiphop0
          Banned
          • Jun 2026
          The "host not found" error usually points to a DNS or hostname resolution problem. Since both proxies work independently, I would focus on checking DNS caches, hostname consistency, and whether the proxy group configuration was affected by the network interruption. I've run into similar troubleshooting situations before, and sometimes a small configuration mismatch can cause surprisingly persistent issues.
