Hi guys,
I'm having some issues on a Zabbix Proxy 3.0.9 (sqlite version) using PSK encryption.
The Zabbix Server received data correctly for half-hour from the proxy and then this error occurred:
I use the same proxy configuration in multiple site and I never had this problem.
The default gateway of the network is a SonicWall router (without the UTM license) not controlled by me. This may be the cause but I'm not sure.
zabbix_proxy.log cannot send history data to server at "***********": SSL_write() timed out SSL_shutdown() with zabsrv.sinfoni.it returned error code 5:
