Error in template "GitLab by HTTP"
  • yetiforce
    • Apr 2025
    I have an error in the operation of the "GitLab by HTTP" template, has anyone had a similar problem and knows how to fix it?
    Preprocessing failed for: <!DOCTYPE html>.<html class="html-devise-layout gl-light" lang="en">.<head>.<meta charset="utf-8"...
    1. Result: <!DOCTYPE html>.<html class="html-devise-layout gl-light" lang="en">.<head>.<meta charset="utf-8"...
    2. Failed: cannot convert Prometheus data to JSON: data parsing error at row 1 "<!DOCTYPE html>": cannot parse metric name
  • avesst
    • Oct 2025
    Did you ever solve this? I seem to have the same issue.
    • jornmul
      • Dec 2025
      Got the same error, fixed by RTFM
      {$GITLAB.HEALTH.TOKEN} macro must have a value : ?token=your_token
      If the value field only has the token you got from your gitlab without prepending it with "?token=", then it fails.
      Cheers,
