Hi Team,
I'm using zabbix 7 with selenium integrated to perform the login check with screenshot. And also I'm using websitebybrowser template with java script but the class browser.findElement is not supported to traverse inside the shadow dom content to identify the Home keyword. Could you please enable "browser" class to support traverse inside the multiple shadow dom and identify the Home keyword
Thanks,
Eswar M
Thanks,
Eswar M
