Faild to send mail notification
  • Cenzoooo
    • Jul 2015
    • 37
    Hello Zabbix community!
    I have problem sending email notifications!
    I configure mail based on this tutorial:
    We bring you the best of industry knowledge through a variety of informational blog posts and articles on the next-gen technologies.
    I did everything, and when i test script by sending email it works fine (i get that mail), but zabbix just don't send me email when triggers appears.
    I use default "Report problems to Zabbix administrators" action, and "zabbix-sendmail" script like it shows in tutorial.
    Even in zabbix Action log in attached picture you can see that action should be successful, what am I missing?
    Do you have any suggestion what I should check? I tried with my corporative mail, and also with gmail, same results, it looks like everything should be fine but I don't recieve notification...
    Thank you in advance,
    Marko
  • vic
    • Jul 2013
    • 58
    Not sure if it's related but I just discovered a similar problem which has always worked in the past. Probably the most important feature I need to work.
    Upgrading from v3.2.5 to v3.2.6 seems to have corrected the problem for me. I was running like this for about a week without knowing I would never be notified if a server went down.
    • Cenzoooo
      • Jul 2015
      • 37
      Do you have link on some good upgrade tutorial? I have 3.2.3 version.
      EDIT:
      NVM, i upgraded version but still no luck
      XXX@XXX:~$ zabbix_server --version
      zabbix_server (Zabbix) 3.2.6
      Revision 67849 4 May 2017, compilation time: May 6 2017 00:49:31
      Copyright (C) 2017 Zabbix SIA
      License GPLv2+: GNU GPL version 2 or later <http://gnu.org/licenses/gpl.html>.
      This is free software: you are free to change and redistribute it according to
      the license. There is NO WARRANTY, to the extent permitted by law.
      • Cenzoooo
        • Jul 2015
        • 37
        I solved problem when i changed "Media type", i had script which was pointing to zabbix-sendmail script from that tutorial.
        I changed configuration to :
        type "Email"
        SMTP server: localhost
        SMTP helo: localhost
        SMTP email: zabbix_T53@...
        And it works now!
        So this thread can be closed!
