zabbix-agent2 Unusual startup error:10.17.53.28:10051: bind: address already in use
  • qiuluomu
    • May 2025
    zabbix-agent ip:10.17.52.47
    zabbix-server ip:10.17.53.28
    zabbix-agent2 use possive mode,The configuration is as follows:
    The error is as follows:
  • Moob
    • Mar 2025
    • 31
    Try changing ServerActive to Server and see what happens.
    ServerActive is the configuration option if you want an active agent, Server when you want a passive agent.
    Regards
    • qiuluomu
      qiuluomu commented
      Hello, active mode is required, passive mode is normal,。and other machines do not have this issue with active mode
    • qiuluomu
      qiuluomu commented
      Sorry for the mistake. zabbix-agent2 was in active mode
  • stadmin
    • Jan 2025
    It seems that a process is already listening on that port. I would check which process it is — maybe it's another instance of the Zabbix agent.
    Check with: sudo lsof -i :10051
    • qiuluomu
      qiuluomu commented
      This machine is a client using active mode of Zabbix-agent2 and does not occupy port 10051。Port not occupied, prompt occupied, quite strange issue。
