Zabbix Trigger Duration Time -1 or 0 Seconds
  • maxhandschild
    • Mar 2023
    • 19
    we are currently on zabbix version 7.0.5 both server and proxy side.
    General info:
    Hosts: 3915
    Items: 376056
    Triggers: 139112
    The problem we have with some hosts is that the trigger is executed and then resolves itself with a duration of -1 to 0 seconds.
    According to research, the problem has been present since version 5.0 LTS. Is there a solution so far? Or has the problem already been fixed in a newer Zabbix version?
    Trigger:
ID:	503259​Click image for larger version
ID:	503258Click image for larger version
    • 5004
    events with negative duration .. Do yo have timesync in place in all hosts?
    • maxhandschild
      maxhandschild commented
      all hosts are ansible managed and have the same configuration for timesyncd
    • 5004
    I can understand the logic, how such events appear with nodata function... But with "last()" ? Never seen it before.. Or heard anyone complain about it.
    I somehow doubt it is Zabbix issue. Something in your environment... But I cannot really put a finger on it...
    How does your item config look like?
    • maxhandschild
      • Mar 2023
      • 19
      here is a sreenshot of the item
        • 5004
        Nothing strange here also... out of ideas for now...
        • compuj85
          • Sep 2025
          FWIW, I'm seeing the same problem in 7.4.2 with events of -1 seconds firing with triggers which come with the Linux Active template, eg Load average is too high.
          A second instance of the trigger fires at the same time, and I find the event doesn't resolve itself even if the condition no longer exists.
          -Jason
