Hi All,
Has anyone been abled monitored disk counters via the zabbix front end using hte perf_counter key? When i run it via zabbix_get it always returns 0.
For disk performance monitoring to work do you have to run the diskperf program on the windows server first?
If i add the same perf_counter in the agentd.conf it returns the data fine.. I am running windows agent 1.1.1 and zabbix server 1.1.4.
Any ideas would be great.
Thanks.
Thanks.
