Zabbix Proxy only polls SNMP item once, then randomly every few hours
  • DmitryMigunov
    • May 2024
    Hi everyone,
    We’re experiencing a strange issue with Zabbix Proxy and SNMP items. For some reason, the proxy only polls the SNMP device once, right after the proxy is restarted. After that, it stops polling regularly and instead retrieves data at random intervals, sometimes only once every 3–4 hours.
    The item interval is correctly set to 1m, and we’ve double-checked all relevant configuration settings. We’ve also tested this behavior with both our own Zabbix server and Zabbix Cloud, using both passive and active proxies — the result is the same.
    We’ve verified that the SNMP device itself is responsive — using the snmpget command manually returns results instantly, with no delay.
    As soon as we restart the proxy, it immediately polls the SNMP item once, and then it becomes idle again for hours.
    Proxy configuration:
    Server=XXX.zabbix.cloud:10051
    Hostname=proxmox-1
    LogFile=/var/log/zabbix/zabbix_proxy.log
    LogFileSize=0
    DebugLevel=4
    PidFile=/run/zabbix/zabbix_proxy.pid
    SocketDir=/run/zabbix
    DBName=zabbix_proxy
    DBUser=zabbix
    DBPassword=password
    ProxyBufferMode=hybrid
    ProxyMemoryBufferSize=16M
    StartSNMPPollers=100
    Timeout=4
    FpingLocation=/usr/bin/fping
    Fping6Location=/usr/bin/fping6
    LogSlowQueries=3000
    TLSConnect=psk
    TLSAccept=psk
    TLSPSKIdentity=proxmox
    TLSPSKFile=/psk
    Has anyone encountered a similar issue?
  • tomse
    • Aug 2020
    Yes.. I've got that problem as well..
    Running 7LTS ubuntu/postgresql and in docker, proxy is 7lts in alpine docker with mysql. using the official docker compose configs.
    Some OID's are polled regularly from the same host, but others take hours.
    and as you said.. random intervals even though poll is set to 50sec (default for one of my triggers).
    would love to hear a solution to this
    • markosa
      • Aug 2022
      • 107
      So, are you using preprocessing and it's feature "discard unchanged / discard unchanged with heartbeat" with those items? That might be in use at template you are using... With tcpdump you may check that if proxy/server is actually doing requests or not, command like : sudo tcpdump -i eth0 port 161 should show all traffic going to port 161(snmp listening port), replace eth0 with your interface name.
