Instability issues using Zabbix Agent 2 7.0.12 with Windows Server 2022
  • scooby-doo_99
    • May 2025
    Hi everyone
    We are facing some instability issues with Zabbix Agent 2 (7.0.12) after migrating the server to 7.0.13
    On some Windows Server 2022 hosts running Zabbix Agent 2 (7.0.12), we are seeing issues where the service just dies and won’t restart, even if the service is set to automatically restart. When looking at the log (Level 4) all we can see that might be related is:
    "lowering the plugin ZabbixSync capacity to hard limit 1 as the configured capacity 1000 exceeds limits"
    We tried what’s recommended in this thread with no luck, it’s still happening:
    Interestingly, two of these 2022 servers were provisioned at the same time from the same VMware template, yet only one is affected by this problem (same installer, same config). Overall, it seems to affect only a very small percentage of our Windows Server 2022 hosts, and mostly seems isolated to this OS. We had sparse, similar issues with a couple of other servers running Windows Server 2003 (Zabbix Agent 5.4.12) and Windows Server 2008 R2 (Zabbix Agent 7.0.3) but to be honest, we just shrugged it off as a legacy OS problem.
    Since we need to keep everything monitored anyway, and as a troubleshooting method, we switched back to Zabbix Agent 7.0.12 and the problem disappeared.
    Has anyone else had or currently have this problem and any insight?
    Here’s our configuration
    Zabbix Web/Server
    Zabbix 7.0.13
    2 servers in Native HA
    Ubuntu 22.04
    6 CPU / 8GB RAM
    Zabbix Database
    Single server
    PostgreSQL 17.5 + TimescaleDB 2.17.2
    Ubuntu 24.04
    12 CPU / 32GB RAM
    Thanks!
  • szabog
    • Sep 2024
    We have almost the same issue.
    We have upgraded to zabbix 7 and distributed the new zabbix 2 agents on every server (7.0.17)
    After that some servers started to throw the zabbix agent unreachable alert, and the agent is stopped. No messages in zabbix log, no events in event viewer only this one: The Zabbix Agent 2 service terminated unexpectedly. It has done this 1 time(s).
    Windows servers are 2019 and 2022 also.
