Hi everyone,
I'm working on integrating Zabbix 7.0 LTS with ADFS using the built-in SimpleSAMLphp (packaged with Zabbix), but I'm stuck on a blocking issue. Environment:
When trying to authenticate via SAML, I keep getting this error:
SimpleSAML\Error\Exception: Cannot retrieve metadata for IdP 'http://adfs.tews-i-rs.lan/adfs/services/trust' because it isn't a valid IdP for this SP.
Things I suspect:
It looks like SimpleSAMLphp is not picking up the metadata from the /usr/share/zabbix/simplesamlphp/metadata directory. Maybe it’s falling back to the vendor path, even though I’ve disabled those files.
No logs mention the custom metadata being loaded, even though I added logging to authsources.php
Has anyone successfully done SAML login with ADFS and Zabbix 7?
Any tips or ideas would be really appreciated!
Thanks in advance
- Zabbix 7.0 LTS on RHEL 9
- Apache 2.4 + PHP-FPM
- ADFS as IdP
- SimpleSAMLphp located in /usr/share/zabbix/simplesamlphp/
- Created and placed authsources.php and saml20-idp-remote.php under:
- /usr/share/zabbix/simplesamlphp/config/
- /usr/share/zabbix/simplesamlphp/metadata/
- Set SIMPLESAMLPHP_CONFIG_DIR:
- In Apache config using SetEnv
- In PHP-FPM pool with env[SIMPLESAMLPHP_CONFIG_DIR]
- Restarted both Apache and PHP-FPM
- Verified certificates and entityIDs match between files
- Permissions look fine (readable by apache user)
- Confirmed no .disabled files are in place
Things I suspect:
Thanks in advance
