Zabbix Agent and Ubuntu 24.04 LTS Install issues - Missing Repo
  • thebunnyman
    • Jun 2025
    Hello, I'm using Ubuntu 24.04 LTS on a few of our production servers. It appears that packages are missing from the Ubuntu Repository.
    I have folllowed the official zabbix documentation; b. Install Zabbix repository
    # wget https://repo.zabbix.com/zabbix/7.2/r...u24.04_all.deb
    # dpkg -i zabbix-release_latest_7.2+ubuntu24.04_all.deb
    # apt update c. Install Zabbix agent
    # apt install zabbix-agent d. Start Zabbix agent process
    Start Zabbix agent process and make it start at system boot.
    # systemctl restart zabbix-agent
    # systemctl enable zabbix-agent
    but specifically for Ubuntu 24.04 I cannot get passed B.3 apt update.
    I've installed Zabbix on hundreds of servers and workstations before.
    Also checked https://packages.ubuntu.com/search?s...s=zabbix-agent for noble (24.04) and the only package that shows up is: Package pcp-export-zabbix-agent
    • noble (24.04LTS) (utils): Module for exporting PCP metrics to Zabbix agent [universe] 6.2.0-1.1build4: amd64 arm64 armhf ppc64el riscv64 s390x
    Which isn't right.
    I do the same for Jammy; Package zabbix-agent
    • jammy (22.04LTS) (net): network monitoring solution - agent [universe] 1:5.0.17+dfsg-1: amd64 arm64 armhf ppc64el riscv64 s390x
    And that is correct -
    I try the same steps for jammy (apt get install zabbix-agent) and it works fine. Issue is most of my systems have been recently updated to noble and zabbix was working at one time for noble. Does anyone know why Zabbix removed their packages from the Ubuntu repos? Right now i'll most likely need to compile for source.
    I promise i'm not crazy.
  • Markku
    • Sep 2018
    • 1788
    Unable to reproduce.
    markku@ubuntutest2404:~$ wget https://repo.zabbix.com/zabbix/7.2/r...u24.04_all.deb
    2025-06-21 14:03:13 (483 MB/s) - ‘zabbix-release_latest_7.2+ubuntu24.04_all.deb’ saved [7104/7104]
    markku@ubuntutest2404:~$ sudo dpkg -i zabbix-release_latest_7.2+ubuntu24.04_all.deb
    Selecting previously unselected package zabbix-release.
    (Reading database ... 73066 files and directories currently installed.)
    Preparing to unpack zabbix-release_latest_7.2+ubuntu24.04_all.deb ...
    Unpacking zabbix-release (1:7.2-1+ubuntu24.04) ...
    Setting up zabbix-release (1:7.2-1+ubuntu24.04) ...
    markku@ubuntutest2404:~$ sudo apt update
    Hit:1 http://security.ubuntu.com/ubuntu noble-security InRelease
    Hit:2 http://archive.ubuntu.com/ubuntu noble InRelease
    Hit:3 http://archive.ubuntu.com/ubuntu noble-updates InRelease
    Hit:4 http://archive.ubuntu.com/ubuntu noble-backports InRelease
    Get:5 https://repo.zabbix.com/zabbix/7.2/release/ubuntu noble InRelease [2424 B]
    Get:6 https://repo.zabbix.com/zabbix-tools/debian-ubuntu noble InRelease [2476 B]
    Get:7 https://repo.zabbix.com/zabbix/7.2/stable/ubuntu noble InRelease [4681 B]
    Get:8 https://repo.zabbix.com/zabbix/7.2/release/ubuntu noble/main Sources [522 B]
    Get:9 https://repo.zabbix.com/zabbix/7.2/release/ubuntu noble/main all Packages [393 B]
    Get:10 https://repo.zabbix.com/zabbix-tools/debian-ubuntu noble/main Sources [1166 B]
    Get:11 https://repo.zabbix.com/zabbix-tools/debian-ubuntu noble/main all Packages [766 B]
    Get:12 https://repo.zabbix.com/zabbix/7.2/stable/ubuntu noble/main Sources [18.8 kB]
    Get:13 https://repo.zabbix.com/zabbix/7.2/stable/ubuntu noble/main all Packages [6228 B]
    Get:14 https://repo.zabbix.com/zabbix/7.2/stable/ubuntu noble/main amd64 Packages [33.0 kB]
    Fetched 70.5 kB in 2s (39.1 kB/s)
    Reading package lists... Done
    Building dependency tree... Done
    Reading state information... Done
    1 package can be upgraded. Run 'apt list --upgradable' to see it.
    markku@ubuntutest2404:~$ sudo apt list --upgradable
    Listing... Done
    ubuntu-drivers-common/noble-updates 1:0.9.7.6ubuntu3.2 amd64 [upgradable from: 1:0.9.7.6ubuntu3.1]
    N: There are 2 additional versions. Please use the '-a' switch to see them.
    markku@ubuntutest2404:~$ sudo apt install zabbix-agent
    The following additional packages will be installed:
    libmodbus5
    Suggested packages:
    logrotate
    The following NEW packages will be installed:
    libmodbus5 zabbix-agent
    0 upgraded, 2 newly installed, 0 to remove and 1 not upgraded.
    Need to get 329 kB of archives.
    After this operation, 927 kB of additional disk space will be used.
    Do you want to continue? [Y/n]
    Get:1 http://archive.ubuntu.com/ubuntu noble/universe amd64 libmodbus5 amd64 3.1.10-1ubuntu1 [34.4 kB]
    Get:2 https://repo.zabbix.com/zabbix/7.2/stable/ubuntu noble/main amd64 zabbix-agent amd64 1:7.2.9-1+ubuntu24.04 [294 kB]
    Fetched 329 kB in 2s (209 kB/s)
    debconf: delaying package configuration, since apt-utils is not installed
    Selecting previously unselected package libmodbus5:amd64.
    (Reading database ... 73076 files and directories currently installed.)
    Preparing to unpack .../libmodbus5_3.1.10-1ubuntu1_amd64.deb ...
    Unpacking libmodbus5:amd64 (3.1.10-1ubuntu1) ...
    Selecting previously unselected package zabbix-agent.
    Preparing to unpack .../zabbix-agent_1%3a7.2.9-1+ubuntu24.04_amd64.deb ...
    Unpacking zabbix-agent (1:7.2.9-1+ubuntu24.04) ...
    Setting up libmodbus5:amd64 (3.1.10-1ubuntu1) ...
    Setting up zabbix-agent (1:7.2.9-1+ubuntu24.04) ...
    Created symlink /etc/systemd/system/multi-user.target.wants/zabbix-agent.service → /usr/lib/systemd/system/zabbix-agent.service.
    Processing triggers for libc-bin (2.39-0ubuntu8.4) ...
    markku@ubuntutest2404:~$ lsb_release -a
    No LSB modules are available.
    Distributor ID: Ubuntu
    Description: Ubuntu 24.04.2 LTS
    Release: 24.04
    Codename: noble
    Maybe provide more information about the problem you see.
    Markku
