Simple question - using internal macros in template triggers expression
  • Andrey.Gavenko
    • Jun 2025
    Hello everyone!
    I'm using zabbix 7.2. I'll try to use the trigger from the book - an error if the device name does not match the name in zabbix:
    Code from example:
    find(/MyTemplate/sysName,,"eq","{HOST.NAME}")=0
    But, in any situation, this expression is considered true. What am I doing wrong?
    The documentation (https://www.zabbix.com/documentation...ed_by_location) states that this macro can be used in trigger expressions.
    Thank you!
    • 4996
    No it cannot .. . There is no "trigger expressions" ...
    {HOST.NAME} → Trigger-based notifications and commands
    → Problem update notifications and commands
    → Internal notifications
    → Map element labels, map URL names and values
    → Item key parameters
    → Host interface IP/DNS
    → Trapper item "Allowed hosts" field
    → Database monitoring additional parameters
    → SSH and Telnet scripts
    → Web monitoring4
    → Low-level discovery rule filter regular expressions
    → URL field of dynamic URL dashboard widget
    → Trigger names, event names, operational data and descriptions
    → Trigger URLs
    → Tag names and values
    → Script-type item and Browser-type item, item prototype and discovery rule parameter names and values
    → HTTP agent type item, item prototype and discovery rule fields:
    URL, Query fields, Request body, Headers, SSL certificate file, SSL key file, Allowed hosts
    → Manual host action script commands, confirmation text
    → Manual event action script commands, confirmation text
    → Manual event/host action URLs, confirmation text
    → Description parameter in Item value and Gauge widget
    → Primary/Secondary label Text parameter in Honeycomb widget
    → Column of data type Text in Top hosts widget
    • Andrey.Gavenko
      • Jun 2025
      Good day Cyber!
      Thank you very much for your help!
      I thought the phrase "Visible host name. This macro can be used with a numeric index, such as {HOST.NAME<1-9>}, to point to the first, second, third, etc. host in a trigger expression." meant it could be used in expressions.
        • 4996
        Unfortunately not... it means you can refer to first, second, etc... host that is used in trigger expression... ie. if you have expression "last(/host1/item)>0 and last(/host2/item)>0 and last(/host3/item)>0" then you can refer to each of those hosts as {HOST.NAME1} or {HOST.NAME2} or {HOST.NAME3}
