Issue with Zabbix 3+ on Centos 7 - setup.php
  • misant
    • Jun 2015
    Hi!
    I installed Zabbix 3.2 (mysql version) on Centos System and met an issue - fronted initial setup was not working, when on http://somehost/setup.php click on "Next Step" nothinh happens.
    Server description:
    1. Centos 7
    2. Nginx + php-fpm
    3. mysql
    What I tried to change:
    1. PHP versions - 5.4, 5.6, 7.1, 7.1 not supported so it showed an error, nothing happens with 5.4, 5.6 on click "Next step"
    2. mariadb5.5, mysql5.7
    3. Zabbix versions 3.0, 3.2 with same result
    Also I installed new server from scratch and got same issue:
    No any errors on nginx, php-fpm or zabbix logs.
    SOLVED:
    Ownership change was needed:
    chown -R nginx:nginx /var/lib/php/session/
  • Atsushi
    • Aug 2013
    • 2028
    Which users did you want nginx and php-fpm to work on?
    If you made it work with nginx users, you need to change the permissions of the various files.
    For example, the following files and directories.
    $ ls -ld /var/lib/php/session/
    drwxrwx--- 2 root apache 44  5月 23 18:28 /var/lib/php/session/
    $ ls -ld /etc/zabbix/web/
    drwxr-x--- 2 apache apache 54  4月 27 11:00 /etc/zabbix/web/
    • misant
      • Jun 2015
      Both nginx and php-fpm are started with "nginx" user
      • misant
        • Jun 2015
        That helped!
        Thank you a lot, with no errors in logs I spent a lot of time to fix it without success. I changed ownership of /etc/zabbix/web, zabbix frontend dir but never met that session folder mentions.
        • Atsushi
          • Aug 2013
          • 2028
          If you are running as an nginx user, please check whether the nginx user can access PHP session management directory.
          Similarly, you need to check the permissions of the /etc/zabbix/web/ directory.
