Zabbix brower item : screenshot function doesn't wait for the page to be fully loaded
  • ThomasP
    • Jul 2022
    We are trying to use the "Website by browser" template to monitor internal web applications.
    We have an issue with one of our applications : loading the page including data (loaded by Javascript) takes some time and Zabbix is only able to a take a screenshot of an empty page (before data got loaded).
    See screenshot below :
    Is there a way to tell Zabbix to wait some data to be available before taking a screenshot.
    Thank you
    Thomas
  • ThomasP
    • Jul 2022
    According to https://www.reddit.com/r/zabbix/comm...wbrowser_item/, it looks like there is no way to delay the screenshot.
    Has anyone played with this feature ?
    Thank you
    Thomas
    • STGA
      • Jul 2025
      You can add this code to delay the screenshot :
      function sleep(ms) {
      const end = Date.now() + ms;
      while (Date.now() < end) { }
      sleep(5000);
      Best regards,
      STGA.
      • RenatoSD
        • Jul 2025
        Thank you
        Thomas
        Hello Thomas.
        I faced the same problem. The solution I found was to add a function to only send the data (JSON) when the script encounters an item that only appears at the end of the page load. For example: my page being monitored has a logo (JPEG), which only appears at the end of the page load. I created a function within the script that only sends the data to Zabbix when this image appears. It's simple; with the help of some artificial intelligence, you can solve it, even if you don't have JavaScript experience.
