Trigger does not fire when using the "Value mapping" mapped value
  • Kapslok
    • Jun 2025
    Hi All.
    Appreciate if you could advise on the following:
    I am using the [net.tcp.port] key with a value mapping.
    This item key returns raw values: 0 - cannot connect; 1 - can connect.
    My value mapping is the following:
    1->Port available (OK)
    0->Port unavailable (Error)
    When I define the trigger problem as following:
    Problem expression: last(/myhost16/net.tcp.port[{$IP},{$PORT}])="Port unavailable (Error)"
    Then the trigger does not fire.
    When I check the item for latest values, my Zabbix shows the mapped value along with the raw one in round brackets:
    2025-06-27 08:16:56 PM Port unavailable (Error) (0)
    2025-06-27 08:15:56 PM Port unavailable (Error) (0)
    2025-06-27 08:14:56 PM Port unavailable (Error) (0)
    2025-06-27 08:13:56 PM Port unavailable (Error) (0)
    When I define the trigger problem statement with the mapped value concatenated with the raw:
    Problem expression: last(/myhost16/net.tcp.port[{$IP},{$PORT}])="Port unavailable (Error) (0)"
    ​Then the trigger does not fire too.
    So my question is - How should I define problem expression - by using the mapped key value, or by using the concatenation of the mapped key value with the raw one.
  • LenR
    • Sep 2009
    • 1011
    You have to test for the 0, think of value mapping for human viewing only.
