Zabbix server:zabbix[process,unreachable poller,avg,busy]): 100 %
  • g18c
    • Mar 2010
    • 9
    Hi am getting warnings of Zabbix server:zabbix[process,unreachable poller,avg,busy]): 100 %
    I have already set:
    Zabbix_server.conf -> StartPoller from 256.
    MySQL conf Max_connections from 512.
    This seems to have made it worse, was at ~80% busy before changes now its stuck at 100%.
    Values per second are ~35.
    Any ideas please?
  • ovas
    • Apr 2017
    • 138
    Hello g18c!
    StartPoller has nothing to do with the error you received, which is about PollersUnreachable. There is this setting that controls Poller Unreachable count in the same configuration file - StartPollersUnreachable.
    With your NVPS count default StartPollers should be fine.
    I would try to fix these unreachable hosts in the long run, though.
