Email message confusing
  • sbdcunha
    • May 2023
    • 27
    I have recently added some RAC Servers and and I have a small confusion regarding the email that I have received when the CPU temp exceeds the threshold value
    Subject:
    Problem: CPU1 Temp: Temperature is above warning threshold: >70
    Message:
    Problem started at 03:58:45 on 2025.07.03
    Problem name: CPU1 Temp: Temperature is above warning threshold: >70
    Host:: HostName_DR IDRAC1
    Severity: Warning
    Operational data: Current value: 63 °C
    Original problem ID: 177125845
    Now as seen above operational data current value is 63 and it says that --- CPU1 Temp: Temperature is above warning threshold: >70 hence it sends a email
    Is this a false positive that the email is fired or am I interpreting the message wrongly
    Appreciate and very grateful if someone can clarify the above
    Thanks and Regards
    simon
  • Markku
    • Sep 2018
    • 1788
    What are the problem and recovery expressions in the trigger?
    Markku
    • sbdcunha
      • May 2023
      • 27
      Dear Marku
      thanks for your quick response
      problem expression:
      avg(/Nutanix_DR IDRAC1/sensor.temp.value[temperatureProbeReading.CPU.1.1],5m)>{$TEMP_CRIT:"CPU"}
      or
      last(/Nutanix_DR IDRAC1/sensor.temp.status[temperatureProbeStatus.CPU.1.1])={$TEMP_CRIT_STATUS}
      or
      last(/Nutanix_DR IDRAC1/sensor.temp.status[temperatureProbeStatus.CPU.1.1])={$TEMP_DISASTER_STATUS} zz0.ix1aou670sizz
      recovery expression
      max(/Nutanix_DR IDRAC1/sensor.temp.value[temperatureProbeReading.CPU.1.1],5m)<{$TEMP_CRIT:"CPU"}-3
      The above is what i see..
      appreciate your assistance
      thanks and regards
      simon
      • Markku
        • Sep 2018
        • 1788
        So now you see that it is not just the temperature value item that affects the trigger, also the temperature probe status is considered.
        As mentioned in the configuration manual (https://www.zabbix.com/documentation...iggers/trigger), the problem expression must evaluate to FALSE as well as the recovery expression evaluate to TRUE in order the problem to recover.
        Markku
        • sbdcunha
          • May 2023
          • 27
          Dear markku
          Thanks once again for the quick reply
          will check it out
          regards
          simon
