VMware plugin: How to identify VM name in alerts instead of vCenter (Zabbix 7.4)
  • tibiki
    • Jul 2025
    Hi everyone,
    I'm using the VMware plugin to monitor vCenter Server with Zabbix 7.4. Sometimes I see alarms like "VMware: Virtual machine CPU usage," but the host appears as the vCenter server itself. Is there a way to display the actual VM name in the alert, instead of just seeing the vCenter as the host? I want to easily identify which VM triggered the alarm.
    Thanks in advance!
    Regards,
  • zekaleka
    • Jul 2024
    • 9
    yes, im interested in solution too.
    Little bit different scenario for me, but equivalent.
    VMSnapshot alarm-701, vm-id-10889.
    Reather i would like to see VMSnapshot alarm-701, vm-Name
    • mpetes
      • Nov 2025
      I have the same problem with Slack notifications. Anyone find some solution for this?
      I get this:
      Problem: VMware: Virtual machine CPU usage
      Problem started at 09:20:49 on 2025.11.04
      Problem name: VMware: Virtual machine CPU usage
      Host: Selska-vCentat00
      Severity: Warning
      Operational data: 5.5152113
      Original problem ID: 11571187
      • mintamanta
        • Nov 2020
        • 14
        Hi all, I was facing this issue. Main problem, that I could not find these problems even in history, only in Action log. Go to Templates -> Vmware ->Discovery -> Get alarms: VMware alarm discovery -> Trigger prototypes.
        Set VMware: {#VMWARE.ALARMS.NAME} to "Create enabled" "No". In this case you DISABLE all VMware alarm related triggers. Personally I don't need any. If you don't want DISABLE all related trigger you should define FILTER values.
        Regards, Mintamanta.
        • zekaleka
          • Jul 2024
          • 9
          It's naughty to provide solution by disabling monitoring at monitoring forum
          But yes, problem still persist, and I can't find solution how to make VM name visible in operational-data / Problem field. (tried #VM.NAME but it didn't helped)
          Let's hope for 2026.! Maybe someone will guide us
