Docker Zabbix server is not running in the UI even though it is
  • brezlord
    • Nov 2024
    I'm running the below compose on TrueNAS scale. Everything works except i get the "Zabbix server is not running" running fault
    The containers can communicate between each other.
    docker exec -it zabbix-web ping zabbix-server
    PING zabbix-server (172.16.20.4): 56 data bytes
    64 bytes from 172.16.20.4: seq=0 ttl=42 time=0.207 ms
    64 bytes from 172.16.20.4: seq=1 ttl=42 time=0.110 ms
    64 bytes from 172.16.20.4: seq=2 ttl=42 time=0.114 ms
    docker exec -it zabbix-server netstat -tuln | grep 10051
    tcp 0 0 0.0.0.0:10051 0.0.0.0:* LISTEN
    tcp 0 0 :::10051 :::* LISTEN​
    Any help would be appreciated.
    services:
      postgresql-server:
        image: postgres:latest
        container_name: postgresql-server
        restart: unless-stopped
        environment:
          POSTGRES_USER: zabbix
          POSTGRES_PASSWORD: Y6ZgRbcWd7MbY2
          POSTGRES_DB: zabbix
        volumes:
          - /mnt/z-flash/apps/zabbix/zabbix-db/postgresql-data:/var/lib/postgresql/data
      zabbix-server:
        image: zabbix/zabbix-server-pgsql:latest
        container_name: zabbix-server
        depends_on:
          - postgresql-server
        environment:
          DB_SERVER_HOST: postgresql-server
          POSTGRES_DB: zabbix
          ZBX_JAVAGATEWAY_ENABLE: true
        ports:
          - "192.168.40.50:10051:10051"
        volumes:
          - /mnt/z-flash/apps/zabbix/zabbix-server/server-data:/var/lib/zabbix
          - /mnt/z-flash/apps/zabbix/zabbix-server/snmptraps-data:/var/lib/zabbix/snmptraps
          - /mnt/z-flash/apps/zabbix/zabbix-server/export-data:/var/lib/zabbix/export
      zabbix-web-nginx-pgsql:
        image: zabbix/zabbix-web-nginx-pgsql:latest
        container_name: zabbix-web
        depends_on:
          - postgresql-server
          - zabbix-server
        environment:
          POSTGRES_DB: zabbix
          ZBX_SERVER_HOST: zabbix-server
          PHP_TZ: Australia/Perth
        ports:
          - "192.168.40.50:80:8080"
      zabbix-java-gateway:
        image: zabbix/zabbix-java-gateway:alpine-7.4-latest
        container_name: zabbix-java-gateway
      zabbix-agent:
        image: zabbix/zabbix-agent:latest
        container_name: zabbix-agent
        depends_on:
          - zabbix-server
        volumes:
          - /var/run/docker.sock:/var/run/docker.sock
  • Answer selected by brezlord at 06-07-2025, 11:20.
    Markku
    • Sep 2018
    • 1788
    Watch this issue for info and progress: https://support.zabbix.com/browse/ZBX-26625
    Markku
    • Markku
      • Sep 2018
      • 1788
      Markku
      • brezlord
        • Nov 2024
        Thanks.
