Alarm won´t be closed
  • SQ_AM
    • Jul 2025
    We have a template that monitors folders and if there are files in the Error folder, an alarm is generated. When a file is deleted from the Error folder, the alarm is automatically closed. The same template is used in all our hosts. Now in one host, an alarm is generated from one Error folder, but it does not close even though the file has been deleted from that Error folder. All other alarms from other Error folders close normally. I removed the host from Zabbix and added it again. When the alarm from that same Error folder came again, the same thing, it just never closes. What on earth can I do with this? It´s driving me grazy!
  • Answer selected by SQ_AM at 06-08-2025, 09:30.
    SQ_AM
    • Jul 2025
    This is solved now. The script gave result 1 even there was no files in the folder. We deleted the Error folder from the server and created it again, after that the script gave result 0. Now the alarm works correctly. Very mystical thing....
    • Markku
      • Sep 2018
      • 1788
      Can you show the relevant configurations?
      Markku
      • SQ_AM
        • Jul 2025
        What configuration you mean? The template config?
        Item
        Trigger has an expression
        last(/Solteq template File Check/FileCount[{#ERRORPATH}])>0​
        On the app server we have a scheduled task which runs this script every day, this creates list of folders we want to monitor
        The agent has user parameters
        UserParameter=FileCount[*],cscript C:\Zabbix2\scripts\FileCount.vbs //nologo "$1"
        UserParameter=Folder.Discovery,powershell -NoProfile -ExecutionPolicy Bypass -File "C:\Zabbix2\scripts\ReadFileList.ps1"
        This template has been working fine and it works in this host with all other folders but when file comes to \\SAF\\El\\Error path, the alarm won´t close even there is no files in that path. In any other path it works fine.
        • Markku
          • Sep 2018
          • 1788
          If you say that the problem does not clear, it means that the item either still receives a positive integer, or there is no new value at all. See the latest values data and the timestamps for the item to see what is happening. Zabbix server/proxy/agent log is also useful if there is something unexpected happening with the item.
          Markku
          • SQ_AM
            • Jul 2025
