I'm running Zabbix via Docker. The Zabbix server is running and I am receiving notifications from Pushover, but the web interface is not working anymore.
The error I'm receiving is
Docker logs are not showing anything useful.
This is my docker-compose
Database error The Zabbix database version does not match current requirements. Your database version: 7040000. Required version: 7020000. Please contact your system administrator.
version: '3.7'
services:
postgresql-server:
image: postgres:16
container_name: postgresql-server
restart: unless-stopped
labels:
- "diun.enable=false"
environment:
POSTGRES_USER: ${POSTGRES_USER}
POSTGRES_PASSWORD: ${POSTGRES_PASSWORD}
POSTGRES_DB: ${POSTGRES_DB}
POSTGRES_SHARED_BUFFERS: "128MB"
POSTGRES_BGWRITER_LRU__MAXPAGES: "0"
POSTGRES_WAL_LEVEL: "minimal"
POSTGRES_FSYNC: "off"
POSTGRES_SYNCHRONOUS_COMMIT: "off"
POSTGRES_WAL_COMPRESSION: "on"
POSTGRES_CHECKPOINT_TIMEOUT: "1d"
POSTGRES_MAX_WAL_SIZE: "1GB"
POSTGRES_MIN_WAL_SIZE: "80MB"
volumes:
- postgresql-data:/var/lib/postgresql/data
zabbix-server:
image: zabbix/zabbix-server-pgsql:latest
container_name: zabbix-server
depends_on:
- postgresql-server
environment:
DB_SERVER_HOST: postgresql-server
ZBX_CACHESIZE: "128M"
ZBX_HISTORYCACHESIZE: "64M"
ZBX_HISTORYINDEXCACHESIZE: "16M"
ZBX_TRENDCACHESIZE: "16M"
ZBX_VALUECACHESIZE: "128M"
ports:
- "10051:10051"
volumes:
- zabbix-server-data:/var/lib/zabbix
- zabbix-snmptraps-data:/var/lib/zabbix/snmptraps
- zabbix-export-data:/var/lib/zabbix/export
zabbix-web-nginx-pgsql:
image: zabbix/zabbix-web-nginx-pgsql:latest
container_name: zabbix-web
depends_on:
- postgresql-server
- zabbix-server
environment:
ZBX_SERVER_HOST: zabbix-server
PHP_TZ: ${PHP_TZ}
ports:
- "${ZABBIX_FRONTEND_PORT}:8080"
volumes:
- zabbix-web-data:/usr/share/zabbix
zabbix-agent2:
hostname: zabbix-agent
image: zabbix/zabbix-agent2:latest
container_name: zabbix-agent2
depends_on:
- zabbix-server
environment:
ZBX_HOSTNAME: "zabbix-server"
ZBX_PASSIVE_ALLOW: "true"
ZBX_ACTIVE_ALLOW: "true"
volumes:
- /:/rootfs:ro
- /var/run:/var/run
- /var/run/docker.sock:/var/run/docker.sock
- zabbix-agent-plugins:/etc/zabbix/zabbix_agent2.d/plugins.d
user: 0:0
volumes:
postgresql-data:
zabbix-server-data:
zabbix-export-data:
zabbix-web-data:
