Can't upgrade from Zabbix 5 to Zabbix 7
  • carnotan
    • Mar 2025
    First of all, a bit of context:
    I have two RHEL 8 servers (one for the frontend on Apache, one for the backend on MySQL ) . Currently running 5.0.35 without a problem. We need to upgrade to 7 (we skipped 6 because of the lack of support for macros). My problem is that I can't upgrade to Zabbix 7 . I strictly follow this instructions: https://www.zabbix.com/documentation.../packages/rhel .
    But when it is time to start the Zabbix Server service it shows this error on the log:
    125290:20250724:102228.863 Starting Zabbix Server. Zabbix 7.0.17 (revision 77c670937ef).
    125290:20250724:102228.863 ****** Enabled features ******
    125290:20250724:102228.863 SNMP monitoring: YES
    125290:20250724:102228.863 IPMI monitoring: YES
    125290:20250724:102228.863 Web monitoring: YES
    125290:20250724:102228.863 VMware monitoring: YES
    125290:20250724:102228.863 SMTP authentication: YES
    125290:20250724:102228.863 ODBC: YES
    125290:20250724:102228.863 SSH support: YES
    125290:20250724:102228.863 IPv6 support: YES
    125290:20250724:102228.863 TLS support: YES
    125290:20250724:102228.863 ******************************
    125290:20250724:102228.863 using configuration file: /etc/zabbix/zabbix_server.conf
    125290:20250724:102228.877 current database version (mandatory/optional): 05000000/05000007
    125290:20250724:102228.877 required mandatory version: 07000000
    125290:20250724:102228.877 mandatory patches were found
    125290:20250724:102228.878 [Z3005] query failed: [1054] Unknown column 'ha_failover_delay' in 'field list' [select unix_timestamp(),ha_failover_delay from config]
    125290:20250724:102228.878 cannot retrieve database time
    For the record, we do not have HA on our installation. Any idea what's going on? Shall I open a bug request? Any help would be much appreciated.
  • Markku
    • Sep 2018
    • 1784
    If you know that you haven't altered the database in any unusual way (by attempting some beta versions or manually editing the schema, or anything like that), you could definitely open an issue at https://support.zabbix.com as they promise direct upgrade path from 5.0.x to 7.0.x.
    Even better if you can provide an easily reproducable case by installing 5.0.35 in a new setup and then upgrading it with the same issue.
    Markku
    • carnotan
      • Mar 2025
      We never attempted any beta versions. Any tests that we take are preceded by an Image in Vsphere (it's a virtualized system) and are therefore reverted. What we do (since this is de DEV environment) is import the production data into this database (but are exactly the same machines, software and Zabbix version). This is done to test and validate the upgrade procedure before doing it in production or any changes that we deem "sensible" are tested before on DEV . Just thought to mention it in case it was noteworthy. I'll open a bug request.
      EDIT: Opened https://support.zabbix.com/browse/ZBX-26759
      • Markku
        • Sep 2018
        • 1784
        Can you share the following outputs from the database?
        select count(*) from information_schema.columns where table_schema = "zabbix" and table_name = "config";
        (my test database has 85 columns in config table)
        select column_name from information_schema.columns where table_schema = "zabbix" and table_name = "config" and column_name like "ha%";
        (my test database has none)
        Here are all the columns in my empty 5.0.35 database:
        select column_name from information_schema.columns where table_schema = "zabbix" and table_name = "config";
        | column_name                |
        | configid                   |
        | refresh_unsupported        |
        | work_period                |
        | alert_usrgrpid             |
        | default_theme              |
        | authentication_type        |
        | ldap_host                  |
        | ldap_port                  |
        | ldap_base_dn               |
        | ldap_bind_dn               |
        | ldap_bind_password         |
        | ldap_search_attribute      |
        | discovery_groupid          |
        | max_in_table               |
        | search_limit               |
        | severity_color_0           |
        | severity_color_1           |
        | severity_color_2           |
        | severity_color_3           |
        | severity_color_4           |
        | severity_color_5           |
        | severity_name_0            |
        | severity_name_1            |
        | severity_name_2            |
        | severity_name_3            |
        | severity_name_4            |
        | severity_name_5            |
        | ok_period                  |
        | blink_period               |
        | problem_unack_color        |
        | problem_ack_color          |
        | ok_unack_color             |
        | ok_ack_color               |
        | problem_unack_style        |
        | problem_ack_style          |
        | ok_unack_style             |
        | ok_ack_style               |
        | snmptrap_logging           |
        | server_check_interval      |
        | hk_events_mode             |
        | hk_events_trigger          |
        | hk_events_internal         |
        | hk_events_discovery        |
        | hk_events_autoreg          |
        | hk_services_mode           |
        | hk_services                |
        | hk_audit_mode              |
        | hk_audit                   |
        | hk_sessions_mode           |
        | hk_sessions                |
        | hk_history_mode            |
        | hk_history_global          |
        | hk_history                 |
        | hk_trends_mode             |
        | hk_trends_global           |
        | hk_trends                  |
        | default_inventory_mode     |
        | custom_color               |
        | http_auth_enabled          |
        | http_login_form            |
        | http_strip_domains         |
        | http_case_sensitive        |
        | ldap_configured            |
        | ldap_case_sensitive        |
        | db_extension               |
        | autoreg_tls_accept         |
        | compression_status         |
        | compression_availability   |
        | compress_older             |
        | instanceid                 |
        | saml_auth_enabled          |
        | saml_idp_entityid          |
        | saml_sso_url               |
        | saml_slo_url               |
        | saml_username_attribute    |
        | saml_sp_entityid           |
        | saml_nameid_format         |
        | saml_sign_messages         |
        | saml_sign_assertions       |
        | saml_sign_authn_requests   |
        | saml_sign_logout_requests  |
        | saml_sign_logout_responses |
        | saml_encrypt_nameid        |
        | saml_encrypt_assertions    |
        | saml_case_sensitive        |
        85 rows in set (0.001 sec)
        Markku
        • tim.mooney
          • Dec 2012
          • 1435
          Search these forums with the text
          ha_failover_delay
          You will see dozens of people that ran into the same problem.
          See Cyber's comments and my comments in this thread: https://www.zabbix.com/forum/zabbix-...%E2%86%927-2-4
