Cannot connect to service "haservice": [111] Connection refused.
  • danveli
    • Jul 2025
    Recently i started experience issue with my Zabbix HA cluster 7.2 where it would just freeze and my two node cluster will seize to function completely for few minutes (sometimes manual restart required)
    Looking at the logs it is something to do with the ha manager process when there is db housekeeping tasks. I upgraded to 7.4 with hopes that it will help but unfortunately it was the same situation.
    My current setup is Zabbix 7.4 , two nodes in HA mode, each of them is also running Mariadb 10.5 + galera and third node as galera witness
    Currently i disabled HA mode since i am having Zabbix downtime few times a day because of the ha manager service. I would like to either resolve the HA mode issue or i would need to look into using pacemakers/corosync instead of the builtin HA mode
    1227296:20250724:053525.954 starting HA manager
    1227296:20250724:053525.954 HA manager started in standby mode
    1214541:20250724:060031.956 "zbx-node1" node is working in "standby" mode
    1227296:20250724:060937.644 [Z3005] query failed: [1213] Deadlock found when trying to get lock; try restarting transaction [commit;]
    1227296:20250724:060937.644 slow query: 7.687342 sec, "commit;"
    1227296:20250724:060937.644 ERROR: rollback without transaction. Please report it to Zabbix Team.
    1227296:20250724:060937.644 === Backtrace: ===
    1227296:20250724:060937.645 10: /usr/sbin/zabbix_server: ha manager(zbx_backtrace+0x41) [0x56152ee4df11]
    1227296:20250724:060937.645 9: /usr/sbin/zabbix_server: ha manager(zbx_dbconn_rollback+0x10b) [0x56152ee39acb]
    1227296:20250724:060937.645 8: /usr/sbin/zabbix_server: ha manager(+0x2741c4) [0x56152ec771c4]
    1227296:20250724:060937.645 7: /usr/sbin/zabbix_server: ha manager(ha_manager_thread+0x42a) [0x56152ec795ba]
    1227296:20250724:060937.645 6: /usr/sbin/zabbix_server: ha manager(zbx_ha_start+0x6d) [0x56152ec7afbd]
    1227296:20250724:060937.646 5: /usr/sbin/zabbix_server: ha manager(MAIN_ZABBIX_ENTRY+0x1089) [0x56152eadeed9]
    1227296:20250724:060937.646 4: /usr/sbin/zabbix_server: ha manager(zbx_daemon_start+0x145) [0x56152ee52405]
    1227296:20250724:060937.646 3: /usr/sbin/zabbix_server: ha manager(main+0x3f5) [0x56152ead2bf5]
    1227296:20250724:060937.646 2: /lib64/libc.so.6(+0x295d0) [0x7f2cbee295d0]
    1227296:20250724:060937.646 1: /lib64/libc.so.6(__libc_start_main+0x80) [0x7f2cbee29680]
    1227296:20250724:060937.646 0: /usr/sbin/zabbix_server: ha manager(_start+0x25) [0x56152ead9f95]
    zabbix_server: ha manager: dbconn.c:1039: dbconn_rollback: Assertion `0' failed.
    1214541:20250724:060938.697 failed to wait on child processes: [10] No child processes
    1214541:20250724:060949.007 cannot pause HA manager: Cannot connect to service "haservice": [111] Connection refused.
    1214541:20250724:060949.007 Zabbix Server stopped. Zabbix 7.4.0 (revision 372a4e93c48).
    1240082:20250724:060959.210 Starting Zabbix Server. Zabbix 7.4.0 (revision 372a4e93c48).
    1240082:20250724:060959.210 ****** Enabled features ******
    1240082:20250724:060959.210 SNMP monitoring:           YES
    1240082:20250724:060959.210 IPMI monitoring:           YES
    1240082:20250724:060959.210 Web monitoring:            YES
    1240082:20250724:060959.210 VMware monitoring:         YES
    1240082:20250724:060959.210 SMTP authentication:       YES
    1240082:20250724:060959.210 ODBC:                      YES
    1240082:20250724:060959.210 SSH support:               YES
    1240082:20250724:060959.210 IPv6 support:              YES
    1240082:20250724:060959.210 TLS support:               YES
    1240082:20250724:060959.210 ******************************
    1240082:20250724:060959.210 using configuration file: /etc/zabbix/zabbix_server.conf
    1240082:20250724:060959.215 current database version (mandatory/optional): 07040000/07040000
    1240082:20250724:060959.215 required mandatory version: 07040000
    1240082:20250724:060959.216 database could be upgraded to use primary keys in history tables
    1240083:20250724:060959.217 starting HA manager
    1240082:20250724:061009.227 "zbx-node1" node started in "standby" mode
    1240082:20250724:061009.227 cannot write to IPC socket: Broken pipe
    1240083:20250724:061023.705 [Z3005] query failed: [1213] Deadlock found when trying to get lock; try restarting transaction [commit;]
    1240083:20250724:061023.705 slow query: 24.486364 sec, "commit;"
    1240083:20250724:061023.705 ERROR: rollback without transaction. Please report it to Zabbix Team.
    1240083:20250724:061023.705 === Backtrace: ===
    1240083:20250724:061023.706 11: /usr/sbin/zabbix_server: ha manager(zbx_backtrace+0x41) [0x562460077f11]
    1240083:20250724:061023.706 10: /usr/sbin/zabbix_server: ha manager(zbx_dbconn_rollback+0x10b) [0x562460063acb]
    1240083:20250724:061023.706 9: /usr/sbin/zabbix_server: ha manager(+0x2741c4) [0x56245fea11c4]
    1240083:20250724:061023.706 8: /usr/sbin/zabbix_server: ha manager(+0x2752ad) [0x56245fea22ad]
    1240083:20250724:061023.706 7: /usr/sbin/zabbix_server: ha manager(ha_manager_thread+0x189e) [0x56245fea4a2e]
    1240083:20250724:061023.706 6: /usr/sbin/zabbix_server: ha manager(zbx_ha_start+0x6d) [0x56245fea4fbd]
    1240083:20250724:061023.707 5: /usr/sbin/zabbix_server: ha manager(MAIN_ZABBIX_ENTRY+0x9e1) [0x56245fd08831]
    1240083:20250724:061023.707 4: /usr/sbin/zabbix_server: ha manager(zbx_daemon_start+0x145) [0x56246007c405]
    1240083:20250724:061023.707 3: /usr/sbin/zabbix_server: ha manager(main+0x3f5) [0x56245fcfcbf5]
    1240083:20250724:061023.707 2: /lib64/libc.so.6(+0x295d0) [0x7f2abac295d0]
    1240083:20250724:061023.707 1: /lib64/libc.so.6(__libc_start_main+0x80) [0x7f2abac29680]
    1240083:20250724:061023.707 0: /usr/sbin/zabbix_server: ha manager(_start+0x25) [0x56245fd03f95]
    1240082:20250724:061024.761 failed to wait on child processes: [10] No child processes
    1240082:20250724:061035.076 cannot pause HA manager: Cannot connect to service "haservice": [111] Connection refused.
    1240082:20250724:061035.076 Zabbix Server stopped. Zabbix 7.4.0 (revision 372a4e93c48).
    1240258:20250724:061045.210 Starting Zabbix Server. Zabbix 7.4.0 (revision 372a4e93c48).
    1240258:20250724:061045.210 ****** Enabled features ******
    1240258:20250724:061045.210 SNMP monitoring:           YES
    1240258:20250724:061045.211 IPMI monitoring:           YES
    1240258:20250724:061045.211 Web monitoring:            YES
    1240258:20250724:061045.211 VMware monitoring:         YES
    1240258:20250724:061045.211 SMTP authentication:       YES
    1240258:20250724:061045.211 ODBC:                      YES
    1240258:20250724:061045.211 SSH support:               YES
    1240258:20250724:061045.211 IPv6 support:              YES
    1240258:20250724:061045.211 TLS support:               YES
    1240258:20250724:061045.211 ******************************
    [mysqld]
    sql_mode        = STRICT_TRANS_TABLES,NO_ENGINE_SUBSTITUTION
    # Data and logs
    datadir         = /var/lib/mysql
    tmpdir          = /tmp
    log_error       = /var/log/mysql/mariadb.log
    slow_query_log  = 1
    slow_query_log_file = /var/log/mysql/mariadb-slow.log
    long_query_time = 1
    # InnoDB tuning
    innodb_buffer_pool_size        = 10G           # ~60–65% of RAM
    innodb_buffer_pool_instances   = 4
    innodb_log_file_size           = 512M         # Enough for high insert rate
    innodb_log_buffer_size         = 512M
    innodb_flush_log_at_trx_commit = 2           # Better performance (risk of minimal data loss in crash)
    innodb_flush_method            = O_DIRECT
    innodb_file_per_table          = 1
    innodb_lock_wait_timeout       = 30
    innodb_deadlock_detect         = ON
    innodb_print_all_deadlocks     = 1
    # Thread and connection management
    max_connections                = 300
    thread_cache_size              = 64
    table_open_cache               = 2048
    table_definition_cache         = 1024
    open_files_limit               = 65535
    # Query cache (off for performance)
    query_cache_type               = 0
    query_cache_size               = 0
    # Temp tables
    tmp_table_size                 = 128M
    max_heap_table_size            = 128M
    # Sort and join buffers
    sort_buffer_size               = 2M
    join_buffer_size               = 2M
    # MyISAM (used rarely)
    key_buffer_size                = 16M
    # Performance schema
    performance_schema             = ON
