no evaluation of calculated item
  • MarKal
    • Nov 2024
    Created item
    Data collection → Templates → Discovery Rule → ##rule## → Item prototypes → ##item##
    with type CALCULATED ITEM
    when i test this item value at
    Data collection → Hosts → Items → Test
    i get proper result
    But in the
    Monitoring → Hosts → Latest data
    item last check and value fields remains blank
    What is the issue here ?
  • Markku
    • Sep 2018
    • 1788
    What is the item interval? Should it have received a value by now?
    Zabbix tries to schedule the items evenly if possible, so not all items are processed immediately after creating them.
    Markku
    • MarKal
      • Nov 2024
      update interval is 1m
      • MarKal
        • Nov 2024
        screenshots about testing
        • MarKal
          • Nov 2024
          item configuration screenshots
          • MarKal
            • Nov 2024
            is there Zabbix server limitation that DISCOVERED items cannot have type "CALCULATED ITEM" ?
            • Markku
              • Sep 2018
              • 1788
              Why is the history set as zero for the item? Then it does not save anything.
              Markku
