Description Filed is broken
  • jayapradha
    • May 2017
    Hi Team,
    Im created a web scenario and when i create a trigger i give the full URL in the description field .We have a ticketing tool in place and we have included the email id for ticketing tool in the notification section of an alert in zabbix. Now the problem is , the description comes broken in the ticketing console.
    for example: in the trigger section on zabbix: www.abcd.status.com
    in the ticket description it is: www.abcd.sta
    Its not complete. Not sure why. We recently upgraded zabbix server fom 2.2 to 3.1.
    please help me fixing this issue.
  • batchenr
    • Sep 2016
    • 440
    Originally posted by jayapradha
    Hi Team,
    if you can see the full name at zabbix trigger- maybe the issue with the ticketing ?
    how do you send it to the ticketing service ?
    can you show the action trigger massage ?
    • jayapradha
      • May 2017
      Hi Team,
      We have a mail ID set up for the ticketing section and we have mentioned that in the action field on zabbix. I have attached few snapshots for your verification.
      Thank you,
      Jayapradha
      • jayapradha
        • May 2017
        Team,
        I havent heard back from you. Please clarify my questions. your response is awaiting.
        Thank you
        • batchenr
          • Sep 2016
          • 440
          Team,
          Thank you
          im not sure what can cut this message.
          but you can try this :
          vi /etc/php.ini
          change this values:
          max_execution_time = 600
          max_input_time = 600
          memory_limit = 256M
          post_max_size = 32M
          upload_max_filesize = 16M
          date.timezone = Asia/Kolkata (your machine timezone)
          other that that.. idk seems like limit issue or in zabbix or in ticketing
          • jayapradha
            • May 2017
            Description Filed is Broken
            Team,
            We tried changing these config values and it did not help. Please suggest the next course of action.
            • batchenr
              • Sep 2016
              • 440
              Team,
              look, if you navigate this action to your mail do you have cuts there ?
              if not its something to do with zabbix and this ticketing
              i think your ticketing program have subject limitation.
              check it out.
              • status ocena
                • Oct 2022
