Unable to install agent2 on Raspbian Bookworm ... libssl1.1 missing
  • gregorywest
    • Jan 2025
    • 11
    I am trying to install the agent2 Zabbix 7.4. I use the following command:
    ~$ sudo apt install zabbix-agent2 -y
    I get the following error messages:
    Some packages could not be installed. This may mean that you have
    requested an impossible situation or if you are using the unstable
    distribution that some required packages have not yet been created
    or been moved out of Incoming.
    The following information may help to resolve the situation:
    The following packages have unmet dependencies:
    zabbix-agent2 : Depends: libssl1.1 but it is not installable or
    libssl but it is not installable
    E: Unable to correct problems, you have held broken packages.
    I have not been able to figure out how to get libssl1.1 install.
    Anyone had this, is there a work around?
    Greg
    • 5004
    libssl1.1 seems to be deprecated for bookwork.. There should be libssl3 instead. Do you have any version isntalled?
