zabbix server fails to read database after upgrade
  • ptera
    • Oct 2014
    • 109
    After upgrading ubuntu to Ubuntu Linux 20.04.6 - zabbix server crashed. Had to backup database and start over.
    After installing zabbix-release_6.0-1+ubuntu20.04_all.deb my zabbix-server fails to start with the following error.
    After restoring the backup and setting permissions...
    250818:192120.155 database connection re-established
    97325:20250818:192120.158 The server does not match Zabbix database. Current database version (mandatory/optional): 05000000/05000007. Required mandatory version: 04000000.
    Help appreciated - we are a large WISP and are blind - not able to monitor for down equipment.
  • ptera
    • Oct 2014
    • 109
    OK I see the database is 050... I just tried to upgrade to zabbix-release_5.0-1+bionic_all.deb
    and got
    The following packages have unmet dependencies:
    zabbix-server-mysql : Depends: libevent-2.1-6 (>= 2.1.8-stable) but it is not installable
    Depends: libmysqlclient20 (>= 5.7.11) but it is not installable
    Depends: libsnmp30 (>= 5.7.3+dfsg-1.8ubuntu3.6~dfsg) but it is not installable
    E: Broken packages
      • 5004
      backup seemed to restore v5 DB (mandatory/optional): 05000000/05000007) but seem you managed to install v4 Zabbix (Required mandatory version: 04000000)?
      I would never upgrade OS under working application, better to prepare new side-by-side platform and migrate application... It seems like you are trying to install now older Zabbix on newer platform which does not support it... Seems like you need a host, which has whatever OS version you had before upgrading... and try to restore there.
      • ptera
        • Oct 2014
        • 109
        Ok I had to trash and start over. I exported all my hosts and templates before hand. When I try to import them into 7.4.1 I get an unhelpfull error.
        Invalid parameter "/55": value (uuid)=(3598da1effdf4ed48074608f1422e3fd) already exists.
        It is a very large file.
        I am trying to figure out how to cut it into sections but I keep getting the jason format error.
        Can some one point me to what is the proper JSON file format?
        • ptera
          • Oct 2014
          • 109
          Ok for my closing - I installed everything new on a different server and tried to upgrade the database 5000000 to 6000000 using instructions from zabbix at
          I got to running "util.exportTable("history_old", CSVPATH + "/history.csv", { dialect: "csv" });" in mysqlsh
          First exportTable was unknwown command replaced with export_table
          Second 'dialect' was undefined name.
          I gave up...
