Triggers created from the Monitoring > Problems page
  • trmbo
    • Sep 2025
    Hi Everyone,
    I created a trigger from Monitoring > Problems > Left click on a problem > Select Trigger > Clone.
    Where is this trigger saved ? apparently It is nowhere to be seen. If I try to create another trigger with the same name, in the same way, the system says that it is already present.
    Where can I find this trigger to check it / edit ?
    Regards.
  • tim.mooney
    • Dec 2012
    • 1432
    You didn't tell us what version of Zabbix you're using, but it should be saved to the triggers for the host that you're applying it to. That likely means Configuration->Hosts .
