Mounted Filesystem Discovery
  • mrco88
    • Jun 2017
    Hello Zabbix Community
    I don't know if it's not possible or a problem of my configuration.
    Zabbix Version: 3.2.6
    Zabbix Agent Version: 3.2.0
    We monitore only Windows Server
    I set up a Filesystem Discovery rule with item/trigger prototype.
    from here: https://www.zabbix.com/documentation...evel_discovery
    With the itemkey "vfs.fs.size[{#FSNAME},pfree]" it found the drives of the System and the trigger works. My Problem is that is a percentage value... so 1TB drives is 20% much more than 20% of a 10GB drive.
    I think it should be work with that itemkey "vfs.fs.size[{#FSNAME},free]" But it wouldn't.
    If I search on google, I don't find anything. It's inpossible, a bug, or is my confuration faulty?
    Thank you for helping me
    greets Mrco
  • mrco88
    • Jun 2017
    Is anyone here, who knows what I mean or is it simply not possible?
    • Atsushi
      • Aug 2013
      • 2028
      Depending on the discovered result, there is a function to switch the value of the macro.
      Please refer to the manual.
      3.9 Using LLD macros in user macro contexts
