JMX - Skeleton Error
  • cht47
    • Jun 2017
    I want to monitor some values of our backend software (tomcat).
    I've installed the Java-Gateway and configured everything. Now I get the following exception:
    java.io.IOException: Failed to retrieve RMIServer stub:
    skeleton class not found but required for client version
    I talked to our head of R&D and he told me that we are not using any stubs or skeletons and I should set the option:
    java.rmi.server.ignoreStubClasses=true
    in the client.
    But where can I add options to the Java gateway (except the conf file)? I've installed it on Ubuntu 16.04 via repository. The server and gateway runs on the same system.
    Thanks in advance.
  • cht47
    • Jun 2017
    bump...
    Upgraded to 3.4, Error still exists.
