Hey,
We followed the instructions in setting up the HyperV script (zabbix_hyperV.ps1) and conf file (hyper-v.conf) for Agent 2 on a MS Hypervisor but we are unable to retrieve any settings for the Guest machines.
The PS script itself seems to be running fine when started on the Hypervisor itself, but the Zabbix template which we added doesn't seem to work. We noticed that the ZBX Agent is also not connecting (we are using a zabbix proxy).
Using any other default Windows SNMP template, the ZBX agent works and shows under availability in the console.
So I'm wondering is there something wrong with the template itself? Why would the agent show offline or not connected when using the original "Template_Windows_HyperV_Host.yaml"
Did I miss something in the instructions?
