[Zabbix 7.4.3] Network Discovery: Discovery doesn't get executed (at all)
  • killom
    • May 2022
    Hello there,
    somehow Zabbix wont start my discovery:
    Click image for larger version  Name:	grafik.png Views:	0 Size:	33.2 KB ID:	507847
    Rule is activated.
    Zabbix Server also has plenty of workers ready:
     ps -eLf | grep zabbix_server | grep -i discover || true
    zabbix     62694   62563   62694  0   21 18:00 ?        00:00:00 /usr/sbin/zabbix_server: discovery manager #1 [processing 0 rules, 0 unsaved checks]
    zabbix     62694   62563   62791  0   21 18:00 ?        00:00:00 /usr/sbin/zabbix_server: discovery manager #1 [processing 0 rules, 0 unsaved checks]
    zabbix     62694   62563   62792  0   21 18:00 ?        00:00:00 /usr/sbin/zabbix_server: discovery manager #1 [processing 0 rules, 0 unsaved checks]
    zabbix     62694   62563   62793  0   21 18:00 ?        00:00:00 /usr/sbin/zabbix_server: discovery manager #1 [processing 0 rules, 0 unsaved checks]
    zabbix     62694   62563   62794  0   21 18:00 ?        00:00:00 /usr/sbin/zabbix_server: discovery manager #1 [processing 0 rules, 0 unsaved checks]
    zabbix     62694   62563   62795  0   21 18:00 ?        00:00:00 /usr/sbin/zabbix_server: discovery manager #1 [processing 0 rules, 0 unsaved checks]
    zabbix     62694   62563   62796  0   21 18:00 ?        00:00:00 /usr/sbin/zabbix_server: discovery manager #1 [processing 0 rules, 0 unsaved checks]
    zabbix     62694   62563   62797  0   21 18:00 ?        00:00:00 /usr/sbin/zabbix_server: discovery manager #1 [processing 0 rules, 0 unsaved checks]
    zabbix     62694   62563   62798  0   21 18:00 ?        00:00:00 /usr/sbin/zabbix_server: discovery manager #1 [processing 0 rules, 0 unsaved checks]
    zabbix     62694   62563   62799  0   21 18:00 ?        00:00:00 /usr/sbin/zabbix_server: discovery manager #1 [processing 0 rules, 0 unsaved checks]
    zabbix     62694   62563   62800  0   21 18:00 ?        00:00:00 /usr/sbin/zabbix_server: discovery manager #1 [processing 0 rules, 0 unsaved checks]
    zabbix     62694   62563   62801  0   21 18:00 ?        00:00:00 /usr/sbin/zabbix_server: discovery manager #1 [processing 0 rules, 0 unsaved checks]
    zabbix     62694   62563   62802  0   21 18:00 ?        00:00:00 /usr/sbin/zabbix_server: discovery manager #1 [processing 0 rules, 0 unsaved checks]
    zabbix     62694   62563   62803  0   21 18:00 ?        00:00:00 /usr/sbin/zabbix_server: discovery manager #1 [processing 0 rules, 0 unsaved checks]
    zabbix     62694   62563   62804  0   21 18:00 ?        00:00:00 /usr/sbin/zabbix_server: discovery manager #1 [processing 0 rules, 0 unsaved checks]
    zabbix     62694   62563   62805  0   21 18:00 ?        00:00:00 /usr/sbin/zabbix_server: discovery manager #1 [processing 0 rules, 0 unsaved checks]
    zabbix     62694   62563   62806  0   21 18:00 ?        00:00:03 /usr/sbin/zabbix_server: discovery manager #1 [processing 0 rules, 0 unsaved checks]
    zabbix     62694   62563   62807  0   21 18:00 ?        00:00:00 /usr/sbin/zabbix_server: discovery manager #1 [processing 0 rules, 0 unsaved checks]
    zabbix     62694   62563   62808  0   21 18:00 ?        00:00:00 /usr/sbin/zabbix_server: discovery manager #1 [processing 0 rules, 0 unsaved checks]
    zabbix     62694   62563   62809  0   21 18:00 ?        00:00:03 /usr/sbin/zabbix_server: discovery manager #1 [processing 0 rules, 0 unsaved checks]
    zabbix     62694   62563   62810  0   21 18:00 ?        00:00:00 /usr/sbin/zabbix_server: discovery manager #1 [processing 0 rules, 0 unsaved checks]
    There are no errors indicating problems with discovery in zabbix_server.log
    What am I missing / doing wrong?
  • killom
    • May 2022
    So I mistakenly entered an security context for SNMP check - that caused the issue. The Discovery was running - but it yielded no hosts.
    There should be some way to audit a discovery. In Webfrontend you are basically running them blind. No info about if and when they are running, and what results / errors they get.
    I had to enable debug logging to be able to get a hint from what might be going wrong here ...
    /solved
