Proxy queue filling up without reason
  • nGeorge3141
    • Oct 2025
    I have a Zabbix Server running locally and a Zabbix Proxy and Agents (passive mode) installed in my Kubernetes cluster using the helm chart (everything version 7.2).
    Currently there are ~ 5000 items collected with the Proxy.
    The problem is, the proxy queue is always filling up after some time so I do not get any more values from the cluster. When I restart the proxy pod, the problem is gone for 18 - 48 hours, then the queue is filling again. I checked the poller utilization and cache size, I can not find the problem. Everything else is working fine on the Zabbix Server, the queue only fills for the proxy.
    I also checked the server and proxy logs, but there was nothing.
    Here are some proxy statistics from the moment where the queue started filling:
    Utilization of agent poller data collector processes: 1.2%
    Utilization of browser poller data collector processes: 0%
    Utilization of http agent poller data collector processes: 0.17%
    Utilization of http poller data collector processes: 0.17%
    Utilization of internal poller data collector processes: 0.02%
    Utilization of ODBC poller data collector processes: 0%
    Utilization of poller data collector processes: 0.002%
    Utilization of snmp poller data collector processes: 0%
    Utilization of unreachable poller data collector processes: 0%
    Configuration cache: 16.6%
    History index cache: 0.36%
    History write cache: 0%
    Utilization of trapper data collector processes: 1.5%
    And some statistics from the server:
    Utilization of agent poller data collector processes: 17.67%
    Utilization of history poller internal processes: 0.14%
    Utilization of http agent poller data collector processes: 6.2%
    Utilization of http poller data collector processes: 8.7%
    Utilization of internal poller data collector processes: 16%
    Utilization of poller data collector processes: 0.1%
    Utilization of proxy poller data collector processes: 12.7%
    Utilization of trapper data collector processes: 0.02%
    Configuration cache: 58.8%
    History index cache: 10.5%
    History write cache: 5.5%
    Trend function cache: 0%
    Trend write cache: 0%
    Value cache: 28.7%
    Value cache misses: 0
    My values.yaml looks like this:
    kube-state-metrics:
      enabled: false
    zabbixAgent:
      image:
        repository: zabbix/zabbix-agent2
        tag: alpine-7.2.0
      extraVolumeMounts:
        - name: <hidden>
          mountPath: /var/lib/zabbix/enc
          readOnly: true
        extraVolumes:
          - name: <hidden>
            secret:
              secretName: <hidden>
      env:
        - name: ZBX_PASSIVE_ALLOW
          value: true
        - name: ZBX_PASSIVESERVERS
          value: 0.0.0.0/0
        - name: ZBX_ACTIVE_ALLOW
          value: false
        - name: ZBX_TLSCONNECT
          value: cert
        - name: ZBX_TLSACCEPT
          value: cert
        - name: ZBX_TLSCAFILE
          value: <hidden>
        - name: ZBX_TLSSERVERCERTISSUER
          value: <hidden>
        - name: ZBX_TLSSERVERCERTSUBJECT
          value: <hidden>
        - name: ZBX_TLSCERTFILE
          value: <hidden>
        - name: ZBX_TLSKEYFILE
          value: <hidden>
    zabbixProxy:
      enabled: true
      resources: { }
      image:
        repository: zabbix/zabbix-proxy-sqlite3
        tag: alpine-7.2.0
      service:
        type: LoadBalancer
        annotations:
          <hidden>
      extraVolumeMounts:
        - name: <hidden>
          readOnly: true
      extraVolumes:
        - name: <hidden>
          secret:
      env:
        - name: ZBX_HOSTNAME
          value: zabbix-proxy
        - name: ZBX_PROXYMODE
          value: 1 # passive proxy
        - name: ZBX_SERVER_HOST
          value: <hidden>
          value: cert
          value: cert
          value: <hidden>
          value: <hidden>
          value: <hidden>
          value: <hidden>
          value: <hidden>
        - name: ZBX_STARTPOLLERS
          value: 10
        - name: ZBX_STARTHTTPPOLLERS
          value: 25
        - name: ZBX_STARTHISTORYPOLLERS
          value: 15
        - name: ZBX_STARTPOLLERSUNREACHABLE
          value: 2
        - name: ZBX_CACHESIZE
          value: 32M
  • PSklyar
    • Sep 2025
    • 30
    Hey, hey nGeorge3141
    Can advise you to start with following steps:
    1) Start with configuration optimizations
    value: "20"
    value: "30"
    - name: ZBX_STARTTRAPPERS
    value: "16"
    value: "128M"
    - name: ZBX_HISTORYCACHESIZE
    value: "64M"
    - name: ZBX_HISTORYINDEXCACHESIZE
    value: "16M"
    - name: ZBX_TIMEOUT
    value: "10"
    - name: ZBX_TRAFFICCONTROLINTERVAL
    value: "60"
    - name: ZBX_PROXYLOCALBUFFER
    value: "12"
    - name: ZBX_PROXYOFFLINEBUFFER
    value: "24"
    resources:
    requests:
    memory: "512Mi"
    cpu: "500m"
    limits:
    memory: "1Gi"
    cpu: "1000m"
    2) Restart proxy to clear accumulated queues
    3) Observe the new metrics over a 24h window
    4) If you still face an issue, you can temporarily enable debug logging
