Mandrake 10.1 - No graphs
  • sharbour
    • Mar 2005
    I've installed Zabbix 1.1A5 on several Mandrake 10.1 boxes, graph png files are not generated with the Mandrake GD module.
    However, they work fine when Zabbix is installed on Mandrake 10.0.
    Is this a known bug? How should I test? Remove the RPM GD module and compile from scratch?
    Thanks,
    Sean
  • sharbour
    • Mar 2005
    Fixed Mandrake 10.1 graphs
    Installing GD from scratch using the defaults worked perfectly.
    Sean Harbour
