Zabbix Appliance 3.2.6 vmdk - Ubuntu display manager fails to start
  • kdesai
    • Jul 2017
    I downloaded the Zabbix Appliance 3.2.6 (latest version) from the Downloads section and started the VM on VirtualBox. The OS boots into console mode. I checked the boot log and it shows the display manager (lightdm) failed to start. Zabbix server and mysql server started fine but it was the OS GUI which failed to start. Is this a known issue? Does anyone know how to fix this?
    What I have tried so far:
    1. Re-install lightdm
    2. Re-configure lightdm as the display manager
    Everytime the failure is with lightdm service. I suspect it has something to do with autologin.
  • wick
    • May 2017
    • 57
    Hi !
    If you have some luck try just a simple
    dpkg-reconfigure lightdm
    service lightdm start
    or
    apt-get update
    apt-get upgrade
    apt-get install aptitude
    aptitude reinstall lightdm
    what about this command :
    service lightdm status
    You can install GDM too an other display manager
    aptitude install gdm
    ps : sorry for my poor english
    • kdesai
      • Jul 2017
      Thanks for the suggestions Wick. I tried above yesterday including the GDM and didn't have any luck booting past the console mode. I abandoned the VM and am installing all packages from scratch on a vanilla Ubuntu VM. I will keep checking this thread since the appliance is hosted for everyone and someone else might run into the problem.
      • bfritz
        • Jan 2019
        I know this thread is a bit old, but I have found to get the GUI for the Zabbix appliance you will need to run
        sudo apt-get install ubuntu-desktop
        It looks like the Desktop GUI is not fully installed with the appliance.
